Jackpoint jack stands
redox
243
15
SF Bay Area
I finally got the chance to try them today while swapping my wheels for my winter set, and I want to say that they worked really well. Robust construction, and the standard pad that came with it was the right size (no overlap with the battery area - I used the rubber pad with the pin).
Kandiru
1,274
492
The main thing is to feel for the lip (the edge of the battery pack shield) starting medial to the jack point. The saddle or pad can abut it, but God forbid you hook up the edge of the pad
onto it, the weight of the car will crush the battery pack.
jerry33
20,025
24,855
Texas
There is a pin on the Jackpoint jackstand that goes in the hole in the Model S' jack point. It won't touch the battery, and you get it right every time.
FlatSix911
Porsche 918 Hybrid
Jun 15, 2015
6,946
6,897
Silicon Valley
Thanks
Photos of?
This... :cool:
kevincwelch
2,062
105
Chicagoland
Yeah, that's my car! I've really been impressed by how easy these things are to use.
I don't use them for simple tire swapping, but in the spring, I really clean out the wheel wells when I put my summer wheels back on. I also use them for cleaning and spraying the rotor hats.
No special adapters needed. Just buy the regular stands.
kevincwelch
2,062
105
Chicagoland
This is the most important thing. Just after engaging the JPJS, I feel between the circular rubber pad and the batter cage. I can barely get a finger between the pad and the cage, and that's sign enough that you've cleared the cage.
