Doesn't the DC to DC converter always top off the 12V? Tesla's shouldn't have this problem
Google Tesla Vampire drain
I currently have the 12 volt battery service message. I stopped by Tesla right when it came on a few days ago but they were too busy to get me in and they told me that I can drive it without a problem until my appointment on the 19th. So I have been doing some reading on the issue and found this:
Understanding the Tesla 12V Battery Service Warning
Thats the unfortunate problem with Tesla service!! With my other cars (Cadillac/Acura) I can get a service appointment same day or next day at the latest. What will happen when the M3 is out? 2-3 weeks for a mere appointment is not acceptable, its even worse when they don't fix your issue.
Tesla has always been great when it comes to service with me. When the service message came on, I happened to be by the service center so I dropped in about 30 minutes before closing and they helped me out explaining the issue and that the battery was just low on charge (and despite charging would not go as high as Tesla's electronics wants it to be at) but would still work fine for weeks.
They also could have got me in within a week but I live in South Surrey and the service center is close to downtown Vancouver (about 1 hour drive). I'm actually downtown tomorrow and they said they could take me but couldn't give me a loaner and I don't want to hang around waiting. I'm next downtown on the 19th and they had a loaner available that day. So that's why it's the 19th. It's no big deal to me. For my last two yearly service they picked the car up at my office and left me with a loaner. They also fixed a door handle in the parking lot of my office. I've had better service with Tesla than with other car dealers.
I have one of these as well but the re-fresh 12V battery is very hard to get to. Thank you TeslaMy bet is on the 12 volt battery too. It's a common problem and one of the side effects is that it throws error messages. He should just pop off the nose cone and attach a booster to the 12 volts contacts that are right there. I carry one of these in my car:
Is the 12 volt battery "jumping" a Tesla endorsed tactic/ Should I get a portable battery jumper pack to keep in my 2016 Tesla?
someone should note that this is only a problem in the older/classic models. AFAIK the problem was corrected in the post '14/'15 models.
Except for those of us who drive a lot, and that 4 years turns into 2 years. Maybe 2.5 if I stretch it.But you can extend the Tesla another 4 years for $4k
June 2015 build, still on my first 12V battery.I have a December 2014 build P85D. I am on my third 12V battery in just over two years. So the problem was not solved by late 2014.
Does the 12V battery failure common with the MX? I have a dashcam hard wired to the car and I don't want that to cause any problems
The next day..
Why remove the face and not try to charge the battery? That makes no sense to me.classic dead 12v behavior, it sat a few hours turned off, 12v battery charge recovers slightly, able to open a door, dash comes on drains the slight bit of charge away, dash goes dead.
If they had brought a way to power up the 12v circuit they could have put the car in neutral instead of fighting so hard to drag it.
Common on Ford CMax Energi and Fusion Energi.It's common in all EVs and Hybrids.
Tesla Model S
Tesla Model X
Tesla Model 3
Nissan Leaf
Totota Prius
You name it (any other hybrid or EV)
12v failure is the number one suspect for random symptoms that aren't easily explained.
Grab a Noco Genius 7.x amp and charge your 12v semi-regularly and it'll reduce your chance of hitting an issue.
Tesla Model S
Tesla Model X
Tesla Model 3
Nissan Leaf
Totota Prius
