Jay Leno's Garage - Roadster 2.0 with Franz
VegasBlue
40
114
Las Vegas
If Tesla is smart they will allow you to choose between a standard steering wheel and the concept wheel.
I was about to say that you would want to choose a standard wheel for the track, but then I realized that formula cars don't have a standard wheel either.
It might be beneficial to have the concept wheel which has the upper portion cut out so it doesn't block the HUD ;)
Reactions: Grendal
aikisteve
238
278
Belgium
They had this steering wheel in Knight Rider (KITT) in the 80's already :D
SDRick
1,434
995
SD CA United States
As long as the car meets the hype and specs, the steering wheel is not much of a concern. What is a concern is that only the acceleration was highlighted in the Leno show, which is pretty much a given. How about the handling? To me, this was a glaring omission. What say you?
Grendal
SpaceX Moderator
Jan 31, 2012
5,696
6,864
Santa Fe, New Mexico
Not that I am any expert on how a car handles, but I'm going to guess that 1800 to 2000 pounds parked about six inches off the ground between four tires is going to be pretty great for incredible handling.
aikisteve
238
278
Belgium
Don't forget about Newton's first law of motion, that explains inertia and the fact that an object wants to keep moving in the same direction unless an external force (grip in this case) is exerted on it. With a lot of weight and high speed, the car has quite a bit of inertia going and will require a large force to change direction. Weight is never a friend of handling and nimble cars.
