DrTaras
R254->R725->S->X->M3->M3P-->R2020?
Car is for sale BTWGlad you guys are getting it installed, but pity the guinea pigs are not putting in the guinea pig work
panjo.com/L/268082
1) Could somebody with a spare mechanical key verify whether you can lock on unlock the car (from the mechanical lock at the bottom of the door) while the Roadster is ON in PARK
Only way I've found to lock the car is with the FOB button (or with OVMS)...and both techniques require the key to be out of the ignition.
2) UK / Japan drivers / RHD Roadsters - can you tell me where the "OBD2" style port (diagnostic port) is located. On the left hand drive cars, it is above the passenger feet on the right side of the car.
This is awesome! Who's car is that? I thought you said there were 4 JdeMOs? (3 in the Los Angeles area & 1 in Seattle)
This gadget may be just what I need. Maybe.
I have a second home in Hawaii. The property doesn't have electrical service available, so I'm "off the grid" with solar.
I can set up the solar with a string of panels, but the current would be far lower than the Chademo can deliver. Up to about 10 amps on a sunny summer day. Half that on a sunny winter day. I wonder if this is flexible enough to function at that low current? I can do the current regulating.
Also, is the computer being updated for the SOC? I'd rather not have it tell me I have 25 miles left when there's a full charge!
It is possible to lock the Roadster via the CAN bus, even when the car is ON. We had to add special code into OVMS to check that the car wasn't on before sending a LOCK command. It would be trivial to remove that protection, should JdeMO users require it.
OBDII port is on driver's side (by law). DIAG port is in passenger footwell.
Yes, the VDS will display the normal data that you're used to (ideal miles, regular miles, range miles), but the instrument panel (where the speedometer is) range data will be WAY off. It takes quite a while (and a bunch of miles) before it starts figuring things out again!!! Just use the VDS.
If you are off-the-grid, you could just trickle charge the car on AC power at 120 volts @ 6 amps (the minimum allowed... less than that signals "digital communication"). But, the Roadster hogs up so much power for the cooling system, you are just going to waste a lot of energy heating up the air. Not recommended for daily drives!!! You would be lucky to add 1 mile per hour (but, maybe that's all you need?)
So, rather than stress your home electrical needs, use JdeMO on your Tesla Roadster to provide a quick recharging away from home, just like a gasoline station for a gas car. Fill it up and drive home. There may be a CHAdeMO station near your house on Hawaii. There are over 13,000 of these stations worldwide:
Next year there will probably be solar charge controllers that can operate at EV battery voltages. Interfacing one of those to a CHAdeMO interface would probably be pretty straight forward. With a small array, you could probably just push everything into the battery until the charge current exceeded the BMS allowable current or top voltage. Then just open the CHAdeMO connection and switch the solar back to charging stationary batteries.I'm 2 hours from the nearest charging of any kind, so I'm trying to work something out for right here.
That means either the 120VAC charging and coming up with a way to turn it on and off to follow the sun and house battery SOC, or go direct to the Roadster battery. I can do it either way, but direct is more efficient. It also gives me the possibility of using the Roadster battery as a last resort for house power.
I may start with 120VAC and do the direct later. Then I would end up with 2 methods. Always good to have a backup! Having the CHAdeMO capability would still be a good idea. There are a few of those on the other side of the island.
Are you working on a process where we would NOT need to leave a key in the car while charging?That would be awesome!!! All the more reason to add OVMS. The wring harness that we build plugs into the diagnostic port, and has a redundant diagnostic port for OVMS or other uses (like actual diagnostic work).
It will be VERY important to have a spare mechanical key in your pocket in case OVMS failed, or phone service failed (or your mobile phone failed). I would suggest an "are you sure? do you have a spare mechanical key?" nomenclature.
I think that's the way it will be, though I don't need a real charge controller. With only 10A max coming in, by the time it got to the constant voltage level it would be plenty charged. Maybe a little too much, like 95%, so I wouldn't need PWM, just shut it off at the right voltage, then reconfigure for house batteries if needed. And update the OBC to the new SOC.Next year there will probably be solar charge controllers that can operate at EV battery voltages. Interfacing one of those to a CHAdeMO interface would probably be pretty straight forward. With a small array, you could probably just push everything into the battery until the charge current exceeded the BMS allowable current or top voltage. Then just open the CHAdeMO connection and switch the solar back to charging stationary batteries.
