There is one in Ohio that has the v3.0 battery, that will have JdeMO installed soon.
Will the charge curve be adjusted for the different chemistry in the 3.0? (And for that matter, is the Roadster charge curve different to the RAV4 charge curve?)
I believe the chemistry is VERY similar which is why we are not using Model S or Model 3 cells. They needed to keep the voltage and charge curves the same so they did not have to tweak the electronics in the Roadster.Will the charge curve be adjusted for the different chemistry in the 3.0? (And for that matter, is the Roadster charge curve different to the RAV4 charge curve?)
True but my understanding is the voltages are VERY similar.Hmm I thought the original Roadster was Lithium Cobalt and the new one a more robust Lithium NMC.
Pretty cool! How are the charge rates on the 50 Kw/125 amp CHAdemo stations?
Why did your PEM heat up in this test? Also, does JdeMO know or care what charging mode you're in (std or range)? I didn't think you were actually in any charging mode during DC charging.I should also mention my car was set to Standard Charge for the test above. I plan on doing a similar test with a Range Charge at some point when I have a long round trip planned.
