JdeMO for the Roadster?
Discussion in 'Roadster 2008-2012' started by dpeilow, Oct 5, 2015.
Tags:
  1. drewski
    drewski Supporting Member
    SF Bay Area
    #461 drewski, Jan 28, 2020
    Electified Garage responded to my Facebook question that they did have to "clearance the trunk" along with the foam behind the bumper.
    If you click on the Facebook link in the video, you'll see their entire response.
    They didn't post any additional pictures.
    From some rough measurements, bumper license plate section to back of trunk box is ~3.5" and it looked like 4.5-5" needed to fit the inlet with current cable configuration (no 90 degree connector to "shorten the bend").
    No pictures from me either, but planning on back-up camera this weekend so can snap some when i'm under there..
    it did look like the cutting could all be the bottom part so under the fake trunk bottom panel piece.
  2. Roadster
    Roadster JdeMO Powered
    SoCal
    BTW, does anyone in VT know who owns the EB 2.5 featured in the video? Really curious if there's enough clearance with the license plate folded down to accommodate the CHAdeMO connector.
  3. drewski
    SF Bay Area
    Convert to 2.0 diffuser. Looks like it would let the license plate fold down lower :D
    That's just eyeballing it, though o_O
  4. Roadster
    SoCal
    Naw. I'm holding out for @CM_007's version of this :D
  5. drewski
    SF Bay Area
    it's a beauty. where do i sign up?
  6. drewski
    SF Bay Area
    oh, it's about 3.75" from front of license plate section of bumper to trunk box.
    i think i eyeballed the cable bend from the JdeMo inlet front needing about 4.75-5" or so . . . maybe 1.25" of trunk would need to be cut out?
    i need to take out the JdeMO cross bar thing, to get a better look, but i thought the cutting could all be below the level of that removable trunk bottom panel thing.
  7. CM_007
    CM_007 Carl Medlock
    WA
    The diffuser in the photos above is not practical for daily use. The four center fins are too low and will catch on too many things and rip the back bumper off.
  8. Roadster
    SoCal
    Whatever you decide to go with @CM_007 will be taken as gospel in these circles.
    Being discussed on FB here with sign up instructions per Carl here.
  9. drewski
    SF Bay Area
    I get the smackdown on both links . . . :( Screenshot_20200208-152623.png
  10. drewski
    SF Bay Area
    The ends of my 2.0 diffuser seems about as low?
    But I'm good with finless! :D
  11. Roadster
    SoCal
    #471 Roadster, Feb 8, 2020
    • Helpful x 2
  12. TOBASH
    TOBASH Supporting Member
    Rockaway Beach, New York
    Are JdeMO charging units still for sale for the Roadster 2.5?
  13. ViperDoc
    ViperDoc Roadster 1305
    Vermont
    That is my EB 2.5. I hope to get the car back after a long stay in NH next weekend. I assume there is room because the Electrified Garage says they have charged the car successfully—so there should be room for the connector! I agree that it might have been better done with the bracket upside down from how it is now, but if it works, I am quite pleased. I also have Stefan's kit that we didn't use, so if someone wants it, I will resell it for less than I paid.
  14. ViperDoc
    Vermont
    I suspect you can still buy them from Tony at Quick Charge power (CHAdeMo charging for Tesla Roadster)
  15. ra88it
    ra88it Member
    Southland
    Yep. When I last asked, they had at least 1 available.
  16. TOBASH
    #476 TOBASH, Mar 6, 2020
    I'm sorry, who do I contact?
    [EDIT] I just saw the reply above and I see a link.... So I called and will order.
    Looking forward to being able to drive all the way to Vermont to enjoy skiing.
  17. drewski
    SF Bay Area
    So you custom fabbed a bracket to hold the inlet. Cool!
    The bolt pattern on the bumper looked similar to Stefan's so I assumed it was from his kit :oops:
  18. ViperDoc
    Vermont
    Actually, I probably shouldn't have said it that way. The Electrified Garage guys came up with the spring-loaded license plate holder, so I assumed they did the whole thing from scratch. Maybe not. Once I get the car next weekend, I will see if they used any componentts from the kit for the inlet parts or not. If I have a complete kit with all the parts I got from Stefan, I will make it available. No point selling an incomplete set. I just figured the postage be less to get it from me than from overseas! I will test the JdeMO on the way home, as I won't be able to make it home in one charge.
  19. TOBASH
    Item purchased. I look forward to long drives with charging on the way.
    Looks like I will keep her.
    Gonna get carbon fiber sills and have some fun.
    Thanks for helping me on this thread!
    Tobash
  20. Roadster
    SoCal
    @ViperDoc were you able to confirm the CHAdeMO handle clears the flipped down plate? Would love to see a photo showing the tolerance if so, thx.
