And i can see there is manny missing in sweden
This is taking a feed from ChargeMap - a community driven map of charging points for electric vehicles so you can add them directly yourself there.
I suggest you calculate C rate for each cell, likely will help answer your question.The concern I would have is if the Roadster battery is capable of being charged continuously at more than 16kW.
This make no sense, cell balancing only kicks in after charging is done.For example, the cell balancing logic may not be able to balance enough current from each cell to prevent overcharging.
I think If it fails it's the car manufacture job to prove that it caused the failure. Also worse case in my view is faster battery degradation which isn't covered by Tesla anyways.Also, I am almost certain Tesla would void any battery warranty if this was used, as this would be operating the battery beyond design specifications.
ESS will kick on cooling if it gets warm, I've done tests and I believe it it can cool the ESS fast for higher C charge rates. Also think about the discharge rates of the ESS on how fast it needs to cool the pack down if you were to take it on a race track....If the battery were not charged over the standard 90% charge then some concerns would be eliminated -- it would primarily be down to cooling. Charging a lithium-ion battery is less efficient than discharging one, so assuming 50kW charging is worse than say 50kW/80hp average power, how well will the cooling system be able to cope with the rate of charging?
C rate for whole pack around ~1C at 50kW charging. Most li-ion cells are capable of this, but there are some cells that are less capable.I suggest you calculate C rate for each cell, likely will help answer your question.
I have worked with batteries that balance during the end stage of charging too. Presumably the existing controller can measure the cell voltages and end charging (or modulate power towards zero) as soon as any once cell hits, say, 4.2V. Will the new JdeMO controller do this? I do not know if the Roadster balances only when charge current is zero or if it balances throughout the cycle. I'm also not sure what the peak voltage they use is, I suspect it's much lower than 4.2V to increase cell lifetime.This make no sense, cell balancing only kicks in after charging is done.
Yes, most likely--but they would also immediately point to such a system in the case of any failure, such as the PEM, because they share the same battery bus. The owner would have to contest such a decision to refuse service. Lawyer up!I think If it fails it's the car manufacture job to prove that it caused the failure. Also worse case in my view is faster battery degradation which isn't covered by Tesla anyways.
Question is, can it do this without air flowing over the radiators? (I haven't looked into it but I'm presuming the Roadster has exposed radiators like the Model S for cooling while driving.) I know the Roadster has cooling fans but is the system purely designed to remove heat generated by 17kW charging? Would 50kW charging be possible given the lack of direct air flow?ESS will kick on cooling if it gets warm, I've done tests and I believe it it can cool the ESS fast for higher C charge rates. Also think about the discharge rates of the ESS on how fast it needs to cool the pack down if you were to take it on a race track....
Pack is 53kwh, so ~1C be at 53kw. You seem worried about this maybe you should find closest cells matching the roadster and run tests on it.C rate for whole pack around ~1C at 50kW charging. Most li-ion cells are capable of this, but there are some cells that are less capable
Switching from CC to CV is a good question, you should find out by asking the project owner for QA and post back here?I have worked with batteries that balance during the end stage of charging too. Presumably the existing controller can measure the cell voltages and end charging (or modulate power towards zero) as soon as any once cell hits, say, 4.2V. Will the new JdeMO controller do this? I do not know if the Roadster balances only when charge current is zero or if it balances throughout the cycle. I'm also not sure what the peak voltage they use is, I suspect it's much lower than 4.2V to increase cell lifetime.
Do you own a roadster because if you did you should know the answer, the electric fans on the radiators have more than enough capacity. Also saying "I know the Roadster has cooling fans but is the system purely designed to remove heat generated by 17kW charging?" is just weird, think about how much is has to remove when you discharge at the maximum rate.Question is, can it do this without air flowing over the radiators? (I haven't looked into it but I'm presuming the Roadster has exposed radiators like the Model S for cooling while driving.) I know the Roadster has cooling fans but is the system purely designed to remove heat generated by 17kW charging? Would 50kW charging be possible given the lack of direct air flow?
How about seeing any of the modified Rav4 EV are having any of these issues? Or how about emailing the project owner for QA and post back here?There are a lot of unanswered questions about this project for me.
So your suggesting no significant car modification should ever be done to a car you own? And always roll over when Manufacturer/"dealership"/Service Center says tough?Yes...and no. Theoretically, it's up to the Manufacturer/"dealership"/Service Center to prove that the modification caused the failure. In practice, they can just tell you "We're not going to work on your car because you modified it." ... I'm also not saying this WILL happen, but I am saying it COULD happen.
I think his point was that when the car is stationary the air flow is completely different than from when you are discharging at maximum rate. You will not be anywhere near stationary when the discharging at maximum rate.Do you own a roadster because if you did you should know the answer, the electric fans on the radiators have more than enough capacity. Also saying "I know the Roadster has cooling fans but is the system purely designed to remove heat generated by 17kW charging?" is just weird, think about how much is has to remove when you discharge at the maximum rate.
Radiator fans are typically not designed for a situation where the engine/motor is at maximum power but the car is stationary. For example, some cars overheat on a dyno when there is no external fan to provide air flow. While in this case, the car is not at maximum power, the difference is that it is at high power for a continuous amount of time (while a typical dyno run lasts an extremely short period in comparison).
Has anyone modded a US Roadster PEM to accept 3ph input for charging?
Having been inside the PEM I can see what needs to happen but would really rather have a working sample to work off of... Perhaps a 3ph input Roadster owner would be willing to post some pictures of the inside of their PEM? It is my understanding (and I may be wrong) that the Euro-spec 3ph variant will allow something like 50% increased charging speed... I know it isn't DC quick charging but it would be an improvement...
The RAV4 EV has the Toyota Smart Key System with push button start. You can take the key fob with you and lock the doors with the mechanical key, leaving the car in READY mode. However, if someone disconnected the charger and broke a window, they could drive off. To me, this is good enough for the kind of locations that host CHAdeMO chargers in California. I would mostly only be gone for a restroom break anyway. The hood also remains open about 8-10cm.Miimura made an insteresting remark. In the RAV4, the car must be on (with key) during the charge. Even if a good location can be found for the charge port, I can't see myself leaving the car with the key in there.
I can only do the cell part, not radiator airflow part (don't have the expertise). The cell I picked as closest is the Sanyo UR18650F (era is correct, Sanyo had confirmed contract with Tesla, capacity 2200-2400mah correct), DC internal resistance is 0.102 ohm. At 50kW and 410V charging voltage, current is 122A. 122A is split over 69 cells in parallel, so 1.77A per cell. That means 1.77A^2*0.102 ohm * 6831 cells = 2.18 kW of heat from cells alone (before module/pack level losses).Roadster has two of these in the 625 CFM 9" Spal Curved Blade Puller Fan 30100452 VA07-AP12/C-58A - Universal Parts Inc. | High Performance Automotive Cooling | Humboldt, IA
over the Radiator, they have plenty of CFM. Why don't you do the math to see how much heat would need to be generated at high charge rate? As if you know the IR of the battery, and charge rate.. you would know how much heat would need to be needed to be removed.
Also if this mod listens to the CAN bus it then would have the ability can back off C charge rate if ESS temp gets to high.. Also be able to see bricks voltages and taper from CC to CV without issues.
.... 4619 CFM from driving airflow. That compares to 625*2 = 1250 CFM with the fans alone.
... At 50kW ... = 2.18 kW of heat from cells alone ... At 16kW charging ... = 0.222 kW, which is a huge difference.
... All this is nonissue anyways if this mod can monitor the CAN bus and thus limit charge rates and temps.
