From the articles you linked in your own post just before this. In particular, Table 4 of this article:
How to Prolong Lithium-based Batteries - Battery University
(I just realized that I kept referring to the car as 70%, but I was using the figure from Table 4 for 60% as I thought you had said that you were seeing 3.92v at 70% on your car, but now I realize I was misreading it.
And, my deadline for editing that post has expired so it will live on with this discrepancy... I'll update my post above, but where I say "70%" that should be "60%", or I could leave it at 70% and use the figures from the 70% line on the table, but it will halve the overall lifetime of the "70% car" I was using for comparison.)
Also, I ballparked how much cycle-related degradation the 70%/60% car might incur in 120k miles or so. It won't be at 100%, but it also won't be at 90% yet (due to cycling degradation). The answer is somewhere between the two. However, since degradation isn't linear it would experience more than a linear amount of degradation. All of the curves shown in any battery degradation graph always start out with steep degradation that levels out over time.
Another thing to keep in mind when you read the graphs is what they mean by a cycle. Typically when talking about the lifetime of a battery they use "cycle" to mean "number of times the full capacity of the battery". But, in graphing some of the study data they can talk about the number of "test cycles" and if the test involves partial discharge and recharge then the number of cycles is misleading. After a number of comments on the article linked above pointing this out, they finally added the footnotes you see now in Figure 6 where they talk about the total energy units available. What looks like severe degradation on the graph (and those of us who have made suggestions about this want them to redraw the graphs) is really not as bad as the graph suggests because you see a ton of cycles on the battery that only used 10% of its capacity per test cycle. You need to divide the cycles on that battery by 10 in order to get an idea of the number of full cycles, i.e. the number of times the full storage of the battery was used, that are represented. In particular, the best line of the graph - for the 75%-65% battery only delivers 90k units over the lifetime of the test whereas the 75%-25% battery delivers 150k units - 2/3 more useful work delivered by the battery that was discharged more and whose graph looks quite a bit more dire.
Yes, but their thanks may be in single digits of dollars given how much the technology in your car will be worth in 10-15 years.
I didn't mean to imply that cycles were the only factor, but we are talking about how high to charge the battery on a daily basis and there is data that shows how different cycles affect the available charge/range. My figures were the degradation due only to the max charge level of the cycling, but as you point out, even with no cycling the ideal doesn't allow for 100% range over time. However, whatever age related degradation occurs, the additional degradation due to cycling will be on the order of what I listed. In other words, the best difference in range you might see in 8-14 years would be 8% between the car charged to 90% daily vs. the car charged to 70% daily. If there was additional degradation due to age alone, or heat in the environment, or any other factor, then the range difference between the two would be even less than 8%. (Simple math - degrading due to A+B vs A+C are closer than degrading due only to B or C.)
