  • The final cut of the 9th episode of the Tesla Motors Club Podcast, featuring Chad Schwitters, the former president of Plug In America, is now available. You can watch it now on YouTube or listen to it on all major podcast networks.
Vendor Jowua: Center Console Hub for 2021 Model 3/Y
The Tesla Model 3 has a lot of functionality, but the front USB ports are always insufficient because you need to connect your music with a flash drive, play Boombox with a flash drive, and use the USB to charge your mobile phone and tablet fast. Because of the rising trend of gaming in a Tesla, two USB ports are not nearly enough, and finding a helpful USB Hub has become the first accessory needed after vehicle delivery.
Recently, Tesla upgraded its center console design, adding a sliding door and two USB-C charging ports inside. Now located up front in the center console, the ports are in an awkward spot for charging devices.
Responding to the refreshed center console, the Tesla accessories brand Jowua has a newly designed hub, designed with drivers behavior in mind. The Jowua LED Hub has four important selling points: fast charging, data transfer, dynamic power control, and LED light.
_TqfSZrv5tVntIeaMge5kbEYHq0srUP2n46D5voeQzQsYIa0KwNYb8AbfZpdpG11CLcHvPSJDbrIbAkMkbCFpiq-2DlNPwo31zMopcNZmtYqtU-jah2McbfRYl7__pCXwTmI71A
Jowua’s 2021 LED Hub is specially designed for the 2021 Model 3/Y refreshed central console and has many innovative features.
4U28_RAmyXyXP2Bo_2MqX1dcRDUwLjqPrjFtEW4C6qo5SDN1f_oA4x9iGxgEFkrb0sgZMIpfi6dhsANmOopChUE6uvpBAckSPTB_xtD7eLG4rtMxY2J-7P00PfK4FDq4PnM269k
The Jowua LED Hub is easy to install – just plug in the two USB-C male ports into the two USB-C ports in the center console.
Features
1. Charging: 27W PD 3.0 fast charging
The Jowua LED Hub has five sets of USB ports in total: 2 X USB-C and 3 X USB-A. With the PD 3.0 fast charging protocol, these two USB-C ports support up to 27W and 18W output individually. When you want to quickly charge mobile phones, tablets, or portable power banks, the two USB-C ports are the best choice. The other USB-A ports are recommended to charge a GoPro, wireless headphones, and other smaller electronic devices.
The dynamic power control of Jowua LED Hub is as follows:
USB-C (No. 1) directly use one Model 3/Y car USB-C current, complete output 27W, not shared by other ports.USB-C (No. 2) and the other three USB-A ports use the other USB-C port’s power, for a total of 27W.USB-C (No. 2) has a full output of 18W, which is not shared by other ports.USB-A (3 ports) supports up to 7.5W output individually. When using the multiple ports together, it shares the 27W with USB-C (No. 2).
Summarizing the above, the Jowua LED Hub can provide a maximum charging output up to 27W + 27W simultaneously. The first USB-C port supports up to 27W full charging speed, and the second USB-C supports up to 18W charging. The remaining 9W can be shared by the other three USB-A ports to charge low-power devices. If the USB-C (18W) is not used, then three USB-A ports will use that power, supporting up to a total of 27 W. Therefore, if there is a need to charge five devices at the same time, the Jowua LED Hub will have absolutely no problem.
NyqpPZtW3IOgMMK5T2C0enZSweE-go4Qm8pusV1FHLF3SlL4ZlKViq4z-pTkJpp3WQESD2R3WeRqGL9_EEKk7GVZgj2Sbj7mKk-uo9cq-Uh14y06GqY_AX_KUAJb46MejwOT6Aw
hYXZnGaXxmuhFS-pk9_1R1XTo66f_Svlu_w-hUDjcCrySRshlqDHM2_7vbDUxoi5UvqKihrV5MOxGkpRmCqKy62ffYFomp7GzDTjoSzMuQu00w6aEsZbP3sAZ8WYqH_KTnNyHvk
oK-_EEEFrCC8ndh1j-IjOKNBMd3ETpj8tf6ULr3ljnL70ihXUATduEq8FqpWGziXsHR049bDsWiZimyCvpxKFGZTOXPlJBrCr0T7Bbxux53C83geoXa-MzGu-1sq3N5fisF5x8A
2. Data Transfer: Connecting game controllers and music flash drives
There are two important uses for the USB ports in a Tesla beyond charging, which both require data transfer – they need to read a USB stick to play high-resolution music, and read input from Bluetooth dongles to connected wireless game controllers. The five ports included on Jowua’s 2021 LED Hub all support data transfer, and can all do so simultaneously.
z__yHETaDfge-szpTlAEA46lTh2-1tegpaTXwmac0JxwCc3svwCz416eU2H_3SI9uOA6mK-e2ZHYRNOIVgKjjraGPyGQokjm1GTI2gcmppJXV-4cX_Pz-v0O5xBkTJVBK-zVHqU
3. Dynamic Power Control: Automatic intelligent distribution of available power
People who have used cheap hubs in the early days have encountered the “USB device failure” warning when using all ports. That happens when the USB current is not properly managed, so if too many devices are plugged in, the hub will crash. Jowua has introduced a Dynamic Power Control system from their previous LED Hub, which has an exclusive, built-in chip and controller to automatically distribute the power supply to all devices. Even when all five ports are being used, each charging device will be automatically and dynamically adjusted and optimized to protect both the devices, and importantly, the vehicle.
_FQxkwlOTke7AoZMji8CWk_d4rgVnJszEvVLXPdjsX1qSIn2UkmvguzpQuKhGINpRpDYS5WcejE1xNtajES7LmmIX8FHYKCl52n0zeRgBRgSbrUwg4aNPH0gNpAsqMAenvxwRMo
4. LED Light: No more looking for things in the dark
Following up on Jowua’s previous hub products, the LED light is again present, but with a slightly different design. The LED light is now vertical to illuminate a deeper and wider area. Because the new sliding door design of the refreshed center console, they’ve removed the light sensor on older models, as it would be too easy to activate mistakenly, and replaced it with a simple on/off button, set in a position that is easy to reach by the driver.
pBGKvn0OtIbcyN0pbXEfY2jxCWquYdMknuIAW3Eog_Dk-EZPwEu2Hj-RSdGzizlfkCmlQxZv9MFNj9qwzc9lrVXIuETMLpVQF9mp-pt_szpuHh71UeprfeC3-xQlqGbCRjz3RBA
x88qdVVtLgZAuYlYDH5nMBvPDjkwys1_-Qhh70HDUv5J3bRgSZJamMQ2i-8Sf14x0soAjuG3bceau_5Dm-W5odkSwikZJnuXSe4okdMPw2XIPzJUbcFgdmpqghIl-upxwcR06XQ
Jowua’s center console tray organizer matches perfectly with the 2021 LED Hub, and they’re the ideal combo for the refreshed center console, satisfying storage and charging needs at one time. With the tray organizer, you can charge your devices under the tray and keep your console neat.
The all-new USB Hub console costs $69 and is currently available for order. JOWUA
Jowua is offering TMC readers a $5 discount off their purchase of Jowua Hub. Just visit Jowua’s website and use the code TMC5 at checkout.
Whether you have the refreshed 2021 Tesla Model 3/Y or an older model, Jowua has a solution for your lighting, data transferring, and charging needs.
Reactions: TomT
rbcopod
‘22 MYLR MSM FSD
Oct 28, 2021
94
121
South Florida
Features
Tesla has removed the data capabilities from the console usb c ports for your product. They are now power only. Kinda defeats the great design of your product. Maybe you can get Tesla to turn the ports back on or design a retrofit to restore the data capability. Thanks.
Reactions: Jowua
these guys have terrible customer support. i had an issue with my $100 charger, contacted them and never heard back
I have the same experience - junk products and horrible support
Just spent 150$ and The USB Hub is CRAP (my does not work and they do not answer emails)
LED light works but it does not charge my phoneand I cannot use the game controller with the USB Hub
