Jumping 12V Battery via Power Port
Discussion in 'Model S: Battery & Charging' started by omarsultan, Oct 3, 2013.
  1. omarsultan
    omarsultan Active Member
    Northern California
    Does anyone know if the 12V battery in the Model S can be jumped via those chargers that connect via the cigarette lighter?
    Omar
  2. EdA
    EdA Model S P-2540
    Cape Cod
    Call your local service center!
  3. ChrisPDX
    ChrisPDX Member
    Hillsboro, OR
    No. The power port is not directly connected to the battery. If the system is off, the port is disconnected from the battery. So if the battery was dead, putting 12v to that circuit would not do anything as it wouldn't make it back to the battery. You must jump the car via the jump posts behind the grill.
  4. omarsultan
    Northern California
    #4 omarsultan, Oct 3, 2013
    Perfect--that's exactly what I needed to know. My Tesla is fine, I just looking for something more wife-friendly then then whole nosecone and jumper cable routine.
    O
  5. brianman
    brianman Burrito Founder
    What about the USB ports?
  6. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Uh, those are supplied via a 5V regulator. Putting 12V in there is going to cause damage!
  7. omarsultan
    Northern California
    I think he was asking is the USB ports have juice if the car is off (for phone charging, etc.)
  8. brianman
    Well, no, that's not what I meant exactly...
    ... nor that.
    Let me try rephrasing:
    Given that the USB ports aren't switched off when the car is in "screens go black" mode, can they be used to trickle charge the car's 12V battery?
    I suspect the rate would be absurdly slow, if possible, but I'm curious nonetheless.
  9. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    I mentioned it in another thread, to charge through the USB port, at maximum rate they can safely handle, your looking at about 2 weeks to recharge the 12v, and prob 24 hrs to get enough power to turn the car on. Another issue is, if the battery is defective and not just dead, it could be "bleeding" off power (self discharging) quicker then you could charge through the USB. That, and going through usb, would also depend on the power circuit. A voltage regulator is converting 12v to 5v, and may not even be capable of shuttling that power backwards.
  10. Puyallup Bill
    Puyallup Bill Member
    Puyallup WA
    I don't know what Tesla is using, but I'm not aware of a DC to DC circuit that can be used 'backwards'. Anyone?
  11. brianman
    How long to get enough power that the 17" will wake up long enough that you can open the charge port?
    (Yes, I've already recommended to Tesla -- months ago -- to add a physical switch to open the charge port.)
  12. umuhk
    umuhk Member
    Pacific Northwest
    Doesn't the charge port open from pressure on the corner by the hinge?
  13. islandbayy
    Charge port can be opened by prying it open slightly. Wont do any good though, without the 12v system "online", the car will not begin to charge (according to what I was told by Tesla).
  14. brianman
    Attempting to rephrase for clarity...
    Suppose your car goes completely unresponsive. Say 1% SOC and empty 12V. How long of USB port charging of the 12V would be required to wake up the 17" long enough to open and unlock the charge port and begin charging? For now let's assume you are "quick like a bunny" with connecting the Tesla end of your UMC (and that the other end was already plugged into a 14-50)?
    Until/unless they give us a physical alternative to nudge the process along, this (USB port) is the best option I've heard so far for waking up a dormant Tesla without moving it and without aid from another vehicle.
  15. Puyallup Bill
    Puyallup WA
    Well, has it in fact been confirmed that you can use the USB port to charge the 12 volt battery? Or, use the USB port to otherwise wake up the car?
  16. brianman
    ".... if it works." :)
  17. Red
    Red Member
    earth
    The lead acid battery has 12v nominal. USB is 5 volts.. You will not be charging it from the USB unfortunately.
  18. islandbayy
    Please, just do not do it. I forsee damaged electronics. The best way of waking the car up is by using the 12v terminals under the nose cone. Quick touch of jumper cables or a boost box is enough to wake the car up. The moment its woken, the DC-DC converter will kick in and start charging the 12v. I highly doubt the circuit for the USB ports could handle the reverse current. I For-See damaging the 12v-5v dc-dc converter in the USB Ports.
  19. Cottonwood
    Colorado
    This discussion is a fantasy anyway. When the 12V battery is dead, and the MS is in a deep-sleep mode, who really thinks the DC-DC converters that supply 5V for the USB ports will be up and running?
