Does anyone know if the 12V battery in the Model S can be jumped via those chargers that connect via the cigarette lighter?
Omar
Omar
Omar
What about the USB ports?No. The power port is not directly connected to the battery. If the system is off, the port is disconnected from the battery. So if the battery was dead, putting 12v to that circuit would not do anything as it wouldn't make it back to the battery. You must jump the car via the jump posts behind the grill.
Well, no, that's not what I meant exactly...Uh, those are supplied via a 5V regulator. Putting 12V in there is going to cause damage!
... nor that.I think he was asking is the USB ports have juice if the car is off (for phone charging, etc.)
I don't know what Tesla is using, but I'm not aware of a DC to DC circuit that can be used 'backwards'. Anyone?A voltage regulator is converting 12v to 5v, and may not even be capable of shuttling that power backwards.
How long to get enough power that the 17" will wake up long enough that you can open the charge port?I mentioned it in another thread, to charge through the USB port, at maximum rate they can safely handle, your looking at about 2 weeks to recharge the 12v, and prob 24 hrs to get enough power to turn the car on. Another issue is, if the battery is defective and not just dead, it could be "bleeding" off power (self discharging) quicker then you could charge through the USB. That, and going through usb, would also depend on the power circuit. A voltage regulator is converting 12v to 5v, and may not even be capable of shuttling that power backwards.
(Yes, I've already recommended to Tesla -- months ago -- to add a physical switch to open the charge port.)
Attempting to rephrase for clarity...Charge port can be opened by prying it open slightly. Wont do any good though, without the 12v system "online", the car will not begin to charge (according to what I was told by Tesla).
Well, has it in fact been confirmed that you can use the USB port to charge the 12 volt battery? Or, use the USB port to otherwise wake up the car?Until/unless they give us a physical alternative to nudge the process along, this (USB port) is the best option I've heard so far for waking up a dormant Tesla without moving it and without aid from another vehicle.
".... if it works."Well, has it in fact been confirmed that you can use the USB port to charge the 12 volt battery? Or, use the USB port to otherwise wake up the car?
Please, just do not do it. I forsee damaged electronics. The best way of waking the car up is by using the 12v terminals under the nose cone. Quick touch of jumper cables or a boost box is enough to wake the car up. The moment its woken, the DC-DC converter will kick in and start charging the 12v. I highly doubt the circuit for the USB ports could handle the reverse current. I For-See damaging the 12v-5v dc-dc converter in the USB Ports.
