Just Ordered 16.32kW w/2 Powerwalls
jjrandorin
Nov 28, 2018
7,197
7,980
Riverside Co. CA
As, that’s really good to know. And it certainly sounds like the system can be manually restarted even during a power failure which makes a whole lot more sense. Someone above had said that once it shuts down then it would not restart until after the grid came back up and I repeated that misinformation.
Still seems quite inconvenient, but certainly not nearly as bad of a problem as I understood it to be.
I havent experienced it (my solar is not big enough, since I have 2 powerwalls and 8.7kW of solar), but I also seem to remember someone saying that it would have to sync to the grid to restart. I havent ever turned either of my powerwalls off since install. If you are going to test it (which would be interesting), I would make sure you are at a point in time where you could be without power for as much as 5 minutes.
Southpasfan
302
436
Pasadena
I think gpez was talking about yet another issue, which was the possibility that the draw from the house exceeds the ability of the powerwalls during a "powerwall only power situation." I think I saw an extensive thread on this having to do with the draw that occurs on starting up an A/C unit.
Swerving back to my issue, it sounds like 3 powerwalls at 5kw each cover the 16.32 system. It does not look like, from the live data I am seeing from my neighbor, that a 16.32 system will ever exceed 15kw, so the forced complete shutdown scenario with no option to cycle on would be avoided.
3 Powerwalls also, of course, make the system that much more likely to be self sufficient, as its much more cushion to make it through a night with 40 kwh as opposed to 27kwh.
Plus in an extended outage those extra 13.5kwh might be significant. Even though I do not live in extended outage territory.
Reactions: jjrandorin
jjrandorin
Nov 28, 2018
7,197
7,980
Riverside Co. CA
Re reading back through my posts in this thread, they come across quite a bit more aggressive than I intended, so I apologize for that. I was also not intending to argue, etc.. just help.
gpez
610
486
I said that, and it's not misinformation. The quote @gpez inserted does not pertain to an overload of solar, instead that is the description of what happens if you overload the PW in backup mode by drawing out too much power. That type of shutdown is resettable as described, but it is not an easy process. The one of concern in this thread is from solar power exceeding PW charge capacity with the grid down.
The official Tesla Powerwall FAQ does not specify that it is only one or the other just that it's "power" so I'm not sure how you're drawing that conclusion. In fact the Powerwall datasheet specifies that the 5kW continuous max power is for both charge and discharge. There is a single inverter that provides this functionality and tripping it by charging or discharging is the same.
The power curtailment @gpez alluded to does not work for the situation of solar power exceeding PW max charge power. The system will instantly shutdown and not reset until the grid is restored.
@power.saver Could you please cite the source for this statement (specifically the bolded part) as it is not confirmed in any of the official Tesla literature I've seen.
Nope :) I believe that FAQ referrs to both charge and discharge limits.
BrettS
2,108
2,511
Orlando, FL
Yeah, I think 3 powerwalls would be perfectly fine for you. Also, remember that to overload it would take 15kW going to the powerwalls, plus whatever your house was drawing at the time. My house rarely goes below 1.6kW during the day and is often closer to 3 or 4kW when the AC is running, so even if your house was only drawing 1kW that would mean that your solar system would have to exceed 16kW before you had a problem with three powerwalls. That would give you even more of a buffer.
Southpasfan
302
436
Pasadena
Most people never even bother with this, and in this case I didn't see them as that aggressive, especially since I was asking the same question multiple times in different ways. :)
Which is always annoying, when it comes right down to it.
power.saver
496
496
Arcadia, CA
I was told this by the Tesla lead installer that did my system. I had solar before getting PWs, and the original design was to have all 3 inverters on 2 PW. But the Tesla lead installer said that would not be safe, and explained to me what would happen in the event of a solar power overload. So we relocated one inverter outside the backup circuit to explicitly prevent it from occurring. This Tesla lead installer had seen it happen at a previous install where they had to go back and fix it, and he didn't want the same thing happening to me.
gpez
610
486
Gotchya. Of course I could be wrong however based on my understanding, conversations with my installer, and the public documentation Tesla provides I believe you were given erroneous information about how the Powerwall behaves in this scenario.
Out of curiosity was that an actual Tesla installer (Solar City) or a certified installer?
power.saver
496
496
Arcadia, CA
Gotchya. I believe that is erroneous information.
They were actual Tesla employees from the Tesla Energy Atwater Village office, not a Solar City or other certified installer.
gpez
610
486
Personally I would go back to Tesla and challenge that because it does not make sense and is not documented anywhere. My installer (local certified) worked closely with Tesla on my install and had no problem with the 8.55kW PV and single Powerwall configuration I have.
power.saver
496
496
Arcadia, CA
Well I suppose on a sunny day with solar power at max and minimal house loads, you could open the main breaker and see what happens.
gpez
610
486
I'm tempted to :) We've had crummy days here and the forecast for the next week+ isn't great. I've been meaning to do some off grid testing anyway.
Southpasfan
302
436
Pasadena
Let’s not have anyone try anything :)
This line of inquiry got started when someone pointed out that my ordered system, 16.32 with two powerwalls, was a powerwall short because it would, in an actual outage, likely shut off.
After quite a bit of back and forth, this much is clear (1) a 16.32 system could easily produce more than 10kw and (2) two powerwalls have a. 10kw Max input and output so (3) the whole system would shut down, as if you didn’t have any powerwalls.
I think Brett summarized it best a few posts ago why this would happen, when he compared a forced shutdown caused by too much power for the powerwalls to take for even one instant with managed on and off cycling based on real time draw.
n8dagr8
105
21
Burbank
Appreciate everyone's discussion here and not to hijack the thread but would a ~12kW system work with 2 power walls or still a potential for shutdown? I'm in SoCal so definitely get some sunny days.
jjrandorin
Nov 28, 2018
7,197
7,980
Riverside Co. CA
You would want to ask your installer, but if you use enough power to want a 12k system, I suspect that you would be fine with 2 powerwalls with that size system.
Southpasfan
302
436
Pasadena
It appears systems can produce, in their best hour, about 85% of their rating. A 12kwh system would be right at 10kw plus 1kw for the hike so two PWs with 10kw capacity are fine by the math.
But that’s why my ordered 16.32 would not be fine by the math. Because if there are only 2 PW the house would need to be pulling almost 4kw (85% of 16.32 is 13.87.
Hence the concern spotted by, I believe, Drsmilie many posts ago.
pdx_m3s
1,230
1,054
Portland, OR
It very much depends on location and panel orientation.
wjgjr
974
731
Silver Spring, MD
Yes, and - as has been mentioned in this thread and elsewhere - the cloud edge effect (forget who introduced the terminology me in a different thread - thanks) can cause significant spikes beyond the normal maximum. With limited monitoring so far, I have seen spikes up to about 40% above the normal maximum power I would expect to see (and hitting right at the limit of my inverter.) I've seen the spike decay back to the expected levels within a minute or two, but it is unclear whether that would be fast enough to not cause an issue for the system (noting that PWs are rated for a surge that also happens to be 40% above normal) if it was designed with little tolerance.
