Thank you for the reply. I guess Tesla wont do much about it? I only has the car for few days and i will see if the data will change (i want to see whats my 90% too). Is "reconditioning" the battery help? (drive to low and charge it back up)
You can roughly determine your 100% rated range at any time, not just at 100 or or even 90: Just divide your current Rated Range by your State of Charge (expressed as a decimal)
(To see both numbers you switch between "Energy" and "Distance" in the Display control panel. Be sure you are always using "Rated" and not "Ideal" , and you obviously need to get both numbers at the roughly the same time)
Example: If I have my battery icon set to display "Energy" and it currently says I have a "64%" State of Charge, and then I immediately switch the display back to "Distance" and it now displays "145 mi", then simple sixth grade math tells me
145 / X = 64% / 100%
ie, X = 145 / .64 = 226.56
So my rated range on a 100% full charge will be close to 227 mi
This is only a rough estimate, again, within 1 of 2%, since there's rounding errors involved, and the whole process is less accurate at a low State of Charge or if the temperature is temporarily high or low, but generally if you do this often enough you will converge on a good estimate of your 100% rated range without actually charging to 100%.
