SoundDaTrumpet
Correct. You don't need a neutral for the HPWC since it's a 240v only device. If you're going with 8AWG for 50A rating, this may save you from having to go to 3/4" conduit depending on your situation.
Agree. One idea is to use 1" conduit. I knew the HPWC at max current needed a 100A circuit, so I installed 1" conduit even though I am using a lesser charging station on #4 wire. My wall is flat so I didn't need to bend conduit for my installation and used elbows to make turns. I don't recommend elbows because wire pulls scratches up the wires pretty good. I should have went with LB and such, or used prefabricated 90 deg bends with couplings. Charging from my existing EVCS or mobile connector should be plenty. Besides Model 3 charging is at 32/40A depending on battery.
I am undecided if the convenience of a HPWC is worth it. I am planning to resort to the J1772 adapter.
