No. If you have a power socket wrench and you don't count the time getting your tools ready then maybe you can do it in 10 minutes, but I doubt it. That also assumes it's warm enough that you don't have to warm up the rubber plugs with a hair dryer (that alone takes 10 minutes) and you don't have to cut and solder any wires which you have to do at least once. It also assumes you don't drop any washers or have to grind off any studs because the nuts rusted and the studs are turning.
It is extremely simple to swap out the lights, we've performed the installation several times now, the longest time it took was 25 mins, and that was due to the lack of lighting at a clients location.
