just reserved solar roof and 2 powerwalls, lets see how long this takes! :D
Discussion in 'Tesla Energy' started by jerjozwik, May 17, 2018.
  1. jerjozwik
    jerjozwik Active Member
    san gabriel valley
    my household has been courting solar ever since we started thinking about EVs, solar city told us our sun facing roof was too small. then comes along solar roof and should allow for some more applicable solar geometries.
    turns out my roof is in dire need of replacement so today i finally reserved the roof. (wife demanded to see it was a real product before agreeing to the reservation.)
    not expecting it anytime soon, just need it within the next to years. my asphalt shingles and plywood base have seen better days...
  2. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Two years? This should be fun... :D We've not had any blow-by-blow on the roof product, so, we are going to be very interested. When it first came out, I had an immediate depo on it and then cancelled it because of cost and time. I then got my roof replaced (hail storm damage) and now am doing the 315W Black Tesla panels. So, your experience will be great to have documented as a comparison!
  3. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I signed up for new construction. Not sure how this is going to work!!
  4. boaterva
    Dayum... hope there's no rush on the house and it's good weather there. Seriously, based on what we've seen, how can they ever keep to a construction timeline unless you frame the house and stop and wait for TE? Or something?
  5. Lloyd
    San Luis Obispo, CA
    My guess is that they will have to place a temporary roof until they are able to get to it.
  6. bishoppeak
    bishoppeak Member
    San Luis Obispo, CA
    I have a deposit down on the Tuscan style roof and two Powerwalls. Hoping for the Powerwalls later this year, no delusions about the timing on the roofing tiles!
  7. boaterva
    Meaning a shingle roof? Or plywood only with paper or tyvek or something? How temporary can it be and be viable as a throwaway?
  8. robwolff3
    robwolff3 New Member
    Ann Arbor, MI
    I also just reserved a roof for a new construction I am building in spring 2019. If I cant get the solar roof in time next year I was planning on doing an array on a traditional roof instead.
  9. Lloyd
    San Luis Obispo, CA
    Not sure, I will post here when I find out.
    For new construction also I will need to know what penetrations they will require for the roof and where they need to be.
  10. miimura
    miimura Well-Known Member
    Los Altos, CA
    If you have an attic space, I don't think the actual penetrations matter. What you should do during construction is provide conduits and pull strings in the walls that can be used for the DC string wiring to the inverters. Conduits can be extended as needed inside the attic space.
    I had my house built with traditional panels in the plan. I told the GC to avoid any roof penetrations for other purposes (plumbing vents, furnace vents, kitchen hood vent) on the SE and SW facing roof sections. That was important because the plumbers would have put a plumbing vent in the middle of my larger array. I also had my solar installer pre-wire while the walls were open. I really like that my solar does not have any visible conduits on the outside of the house.
  11. jerjozwik
    san gabriel valley
    • Funny x 2
  12. boaterva
    May your winds be calm.... :D
