Keep tesla 3 in garage with high and cold weather
I live in the northeast and my garage can be really hot in the summer (> 90F) and cold in the winter (20-32 F normally). How would this affect the battery to Tesla 3? If it harm it, what can I do to help keep the car in good condition without remodel my garage? My garage is neither insulated nor climate controlled.
What if I leave the car in the garage for 2-3 months? Should I keep in plugged or not? Will there be any issue?
Keep it plugged in as much as possible, and set the charge limit to 70% if being unused for long amounts of time (over 2 weeks at a time). 90F isn't really a big deal for the batteries. Neither is the 20F, since outside would be worse. The car should be fine.
Reactions: M3BlueGeorgia
That is not really hot or cold really.
There is nothing you need to do, you can just follow the "a plugged in Tesla is a happy Tesla" mantra.
Reactions: RScottyL
I'm curious, why 70%? Is this a number you pulled out of the air or something related to a parked tesla?
Reactions: voip-ninja
If you park it when 80% to 90% charged, plug it in and set the charge limit to 70%, its unlikely the car will actually need to charge the batteries if you leave if for a few weeks. Any power it needs to temperature-protect the batteries or to check for updates will come from the house's power.
That would be my take on the "70% theory", but yes 70% is arbitrary and just happens to be the midpoint between 50% and 90%.
Anytime you aren’t driving it for months at a time, I would recommend setting the charge limit to 50%
When ready to use it, bump it up.
Otherwise 70% to 90% is fine.
I mostly just pulled it out of the air based on prior knowledge, but closer to 50% SoC storage is healthier for the battery. You can also leave it at 50% if you wish, but I don't think the difference would be much. For super long term storage, I do believe you'd see better results storing at 70% instead of 90%, but probably not much of a difference storing at 50% instead of 70%.
