For those of you who are using the 12v CTEK quick disconnect and coming out the nose, etc., there is an easier way that several of us have used to connect the CTEK to the 12v system (images below courtesy of Ingineer). Scott mentions this above, but here are some photos that show how to make the cigarette lighter plug hot all the time in the car. Amazon carries CTEK accessories such as a cigarette lighter plug. So all you have to do is roll the window down slightly, plug in the CTEK cigarette lighter plug into the socket and power the 12v vampire load with the CTEK. You'll never forget about it and drive away because the wire goes into the driver's window and it is very visible.
In the frunk, remove the top cover to reveal the fuse and relay bank. Remove the black cover on the left bank and remove the relay as shown. Crimp a short jumper to go into the relay socket as shown and bypass the relay. This makes the cigarette lighter plug hot all the time...Pretty easy to do and once you do this and hook up your CTEK, your car will never lose any range sitting in the garage because the vampire load will be powered externally and won't have to be serviced by the main battery pack...
