What are you trying to use? Keep the air or heat on? The easiest way is to just keep a door open a crack. Alternatively, the "remote S" app has a camping mode which will keep the HVAC on.
You can keep the driver's door ajar, or, use your app to keep AC on, or you can also shift to N, apply parking brake from the center console, then get out. These methods will give you about 30 minutes until shutdown.just hanging out in the back seat and stuff... I did notice when I had all doors open, it never powered off
Any tips on this? I place a bag in the driver seat so that it senses the weight, but that only gives about 15 minutes before everything shuts off.
How do you engage camping mode?What are you trying to use? Keep the air or heat on? The easiest way is to just keep a door open a crack. Alternatively, the "remote S" app has a camping mode which will keep the HVAC on.
Right... just "hanging out".just hanging out in the back seat and stuff... I did notice when I had all doors open, it never powered off
Right... just "hanging out".Try leaving the front door open just a sliver if you want to listen to romantic music while you're in the back seat with your significant other!
(sorry, couldn't resist!)
I remember getting that update in December. Before that, I would have to tap on the screen to wake things up after the driver left. After the update, things would stay on.They added like last Nov/Dec in the software update a fix for this somewhat. I believe as long as weight in the passenger seat for sure, and potentially back seats (not sure) are present, the power and A/C will remain on now, I believe with a 30 minute limit or so though.
I that case, why would it matter to him if it shuts down after 15 minutes...?
(sorry, couldn't resist either).
