Key Card Troubles
Have you had trouble opening/starting the car with...?
  • Total voters
    34
Pons
New Member
Jul 23, 2018
2
2
Rancho Cucamonga
Tapping the Key Card on the center of the pillar or on the cup holders works sometimes, but not every time. And it seems to be getting worse.
Does anyone else have this problem? Anyone need a replacement card?
Is there a trick to make the RFID card more effective? I feel dumb trying to tap my car open for 5 minutes. Anything else I can try? I park under solar panels at work. Could the noise cause the cars reader to malfunction, or is my card becoming defective?
Luckily the phone key has been working well.
From https://www.tesla.com/support/model-3#key-card-entry
"To lock or unlock, tap your Model 3 key card on the center of the pillar to the right of the driver’s window. To start your Model 3, tap your key card behind the cup holders, place your foot on the brake pedal to start."
miimura
6,569
6,372
Los Altos, CA
I don't tap the card on the pillar, I swipe it from the camera down the pillar. You might be missing the right spot, swiping will alleviate that issue.
Also, if the car doesn't unlock with the phone, I open the app, then swipe up the control panel and toggle Bluetooth Off and On. That works 100% for me to get the phone to connect to the car as a key. I have an iPhone 6 on iOS 10. I only use the key card if I just need to get into the car to retrieve something and don't need to drive it. I have never had to use the card to drive.
ewoodrick
5,285
4,270
Buford, GA
Don't tap, hold for a few seconds. On the outside, it is just below the camera.
On the inside a recommend laying it down between the back cup holder and the storage compartment.
Works every time for me.
RayK
2,222
2,220
San Jose, CA
Can't properly vote. I exclusively use the keycard and have not had any problems opening or starting. So if I select NONE, it implies that I have not had problems with the phone as key. Which I can't confirm since I've never linked my phone to the car.
Since owning the 3 I have NOT swiped the card down the B-pillar. Just hold it against the car about two inches below the camera. I keep the card in a clear plastic holder by itself; no other RFID chips like my work badge or ChargePoint tag.
Reactions: noicepls
scottysize
111
83
Sanger, TX
Key card works every time. I don't even have to take it out of my wallet. I just tap my wallet on the pillar and the door unlocks.
Several times my iPhone X hasn't unlocked the doors by pulling on the handle. I have to try 2 or 3 times before it finally unlocks.
Reactions: noicepls
Ejl80
597
546
Nj
Is background data on?
Acps110
71
233
Charleston, West Virginia
One thing to point out with the keycard... Both the Tesla logo on the front and the pictograph on the back are printed in the wrong orientation. Both are printed landscape when the key is meant to be used in the portrait orientation.
