I'm having issues with the Model 3 key fob passive entry feature.
When I walk up to my car with the key fob, I experience delays ranging from 2-15 seconds while pressing the door door handle, before the door opens. I also experience this issue when pressing the button on the charging cable. If I have accessed the car recently (1-2min), there is no delay.
I setup a mobile service appointment, and after some investigation, the tech said the key fob operates differently from the phone. Apparently the unlock command is only sent when the door handle is pressed, as opposed to the phone which unlocks the car when you get near. I'm not sure that is accurate, or at least the reason for the delays.
I've only had my car for 3 months, and the key fob for about 2 months. I've tried 3 different batteries in the key fob, with no apparent effect.
Does anyone else experience this issue? Is this an issue with the key fob or car, or just a known quirk?
