When I come back to the locked car it will not unlock. I have to use the Fob. It has only happened 3-4 times in the last 6 weeks. Normal?
Thanx, that would explain why it does not happen when approaching from the front of the car.
The car is really good about telling you when the battery is low. They last 9-12 months, probably closer to the 9 month time frame for me, and I just had to replace mine for the second time.I'd start by replacing the battery. Or at least check its voltage. It's cheap to do, and it could be the issue. And even if it's not, at least you know you have a good battery there, which should last at least a year. Some fobs eat batteries, but others don't. Maybe somebody with a Tesla fob can chime in and tell you about how long it should last.
This is a thread about the key fob, which is a way to avoid the problem you're having.I use my phone to unlock my car and 5 out of 10 attempts are fail! I repeatedly have to pull the door handle until it recognizes me and that is so annoying!
That definitely shouldn't happen. But did it start happening all of a sudden, or since day 1? Remember the phone-as-key only works when very close to the car, and BT can be blocked by other electronic devices, or even your own body, if you have the phone on your back pocket. I typically carry the phone with my wallet when walking to the car, and haven't had an issue so far. I've had issues, but that was operator error, like the app being in the background, forgetting to turn BT on. We're getting the hang of all of that by now, after 1+ months of ownershipI use my phone to unlock my car and 5 out of 10 attempts are fail!
