Key fobs.
Discussion in 'Model X: Battery & Charging' started by Dr. John, Aug 7, 2018.
  1. Dr. John
    Dr. John Member
    United States
    Key fobs don't let doors open. New batteries no help. Checked 12v battery with charger and it is good. SC says need new fobs and must program at car not over internet. Others with same problem?
  2. Sandiegodoug
    Sandiegodoug Member
    SAN Diego
    Yes
    We had a kfob fail. Put new batteries in and still didn’t work. They wanted me to leave car but I insisted and the ranger came out with new fob and programmed it in my driveway.
  3. dethman
    dethman Member
    socal
    both fobs?
    yes the fob has to be programmed at the car. i received a new fob and mobile service had to come and program it.
  4. Sandiegodoug
    Sandiegodoug Member
    SAN Diego
    Only one failed
  5. Sandiegodoug
    Sandiegodoug Member
    SAN Diego
    Funny, the 1st replacement failed too,
    Luckily, he had another one, and was able to
    Program it to our car.
  6. jboy210
    jboy210 Supporting Member
    Interesting that replacing the battery did not help. My car died at a shopping center and had to be towed. They had me put my keyfob in the car and remove the battery from it so the car would not detect the presence of the fob. Phone support then locked the car. When the tow driver came he had phone support unlock the car. He then inserted the battery and put the car in tow mode.
  7. Sandiegodoug
    Sandiegodoug Member
    SAN Diego
    Ranger told me key fobs go bad. It was nothing we did, and one original fob worked fine. Replaced battery anyway
  8. Dr. John
    Dr. John Member
    United States
    Both my key fobs died at same time and would not open driver door. Got it open and had to leave one fob in center console under 12v outlet to drive and leave unlocked after that. Ranger brought two new fobs and programmed them to car. Also replaced fwd top seal on the driver side and new window wipers as each were showing signs of deteriorating. Seals had been on order earlier so all was done at once in my garage for NC. Thanks Tesla.
  9. GoCanes
    GoCanes Member
    Miami, Florida
    BTW, do NOT leave your key fob in your jeans pocket when you throw it in the wash - the fobs don't like water apparently... After drying it out and putting in a fresh battery, it still works, but the X constantly shows the "replace key fob battery soon" notice.
    Also, I purchased replacement batteries from Amazon recently and got a bad batch - had to re-order another one to get my good (non-laundered) fob to work. Maybe I should have paid more than $3.89 for the batteries??
  10. DCGOO
    DCGOO Member
    Indianapolis, IN
    The SC will replace your batteries for free
  11. Kacey Green
    Kacey Green Member
    Charleston, South Carolina, United States
    Different fobs but our Model S had a fob go bad right after we bought it
