I see. Can somone point me to some measurements? I'm also curious about the total kwh required to charge from 0-100%, compared to the battery capacity.
I don't have a reference to the thread, sorry, but somewhere on these forums someone graphed the data. It pretty tightly aligns with my formula above (which was nice to see, phew).
So for total kWh from 0-100%, it will depend on your charging setup. The last bit of charging also takes roughly an hour more than if it could keep charging at full speed, which means an extra 0.3kWh is wasted charging to 100% (an hour of that 300W overhead).
But 0-100% isn't really realistic, yet makes the calculation much more... difficult? So let's take 10-90% of my 2019 Model 3 LR AWD. It's degraded a bit, but my "usable" (0-100%) capacity is about 69.0kWh.
10-90% is 80%, and 80% of 69.0kWh is 55.2kWh. I can redo the above formula for
energy (kWh) instead of
power (kW) - the ratio of net/gross power will be the same as the ratio for net/gross energy.
Gross Energy (AC) = Net_Energy_DC / Efficiency
= 55.2 / ( 0.94 - ( 300 / (Volts x Amps) )
So various values that come with that, to charge 55.2kWh:
What's interesting to note is that you
divide by the efficiency, which multiplies by a "worse" amount. 73% efficiency means 37% more energy required (not 27%). 90% efficiency means 11% more energy required (not 10%).
Takeaway: avoid very low power charging like a standard 120V outlet.
