I admit that Vegas is not well plug served yet (100 Model S' are moving into town) but "screwed" is a matter of an owner's time and willingness as an early adopter.
If you had an early cell phone you had to drive all around till you could find a working tower.
With an EV you have many phone apps that tell you were to plug in. For instance with preplanning you might take advantage of the Cosmopolitan with a 70A Roadster plug. The highway to Vegas has the Barstow McDonald's 70a Roadster plug and several along the way there are Nissan dealerships with J1772s. Ideal? No. Screwed? No again.
That circle is part of the sign! :
Esper machine:
Time machine:
I did LA to Vegas and back in a single day last week. The Barstow charger worked fine, but I think "screwed" would be the correct term if I had to spend 4+ hours at a J1772 in Barstow. Once I got there, there were two Volts in the Venetian spots (!) so I went straight to the Clark County Government Center and took a cab back to the strip. Either the hotels need to step it up, or we need a Supercharger in Primm. I was only getting 18 mph from the J1772 and ended up leaving Vegas with 175 rated. It was pretty windy and hilly and I hit 0 rated miles when I was 2 miles away from Barstow, but still made it.
...with all the Zappo's model S cars being added to the LV pool of cars, I bet its going to be pretty hard to find a spot to charge on the strip come next summer or fall. ...
What seems to happen in an area is the the infrastructure adjusts to the local demand.
I'm guessing from your photos, the last (new) charger on the right in last photo, is going to have the stripes removed from the pavement? But it looks lie, a narrow spot. And if not, how do you access that charger?
With adapter?
175 rated is quite brave of you. I was looking at the different changes in elevation between Las Vegas and Barstow and there are at least two peaks. I'm sure others who know the terrain will correct me further but I noted that there was a 4700 feet peak and then a drop a couple thousand feet followed by another 4300 or so peak. Then the drop in elevation again into Barstow. All of those peaks and valleys are what turn an inherently doable 160-170 mile drive into a 175-200 rated mile drive (depending on conditions/avg speed). If you consider that you'll lose 7 rated miles per one thousand foot climb but only "gain" back 4 rated miles per thousand feet drop in addition to the miles travelled, it all makes sense.
I was expecting this experience that you described, Volt, Plug in Prius, plugged in at the J1772 spots. It only takes a couple of these hybrids (ok....range extended EV) to make you switch to plan B or plan C.
I think if I was in your situation, pressed for time, I would have perhaps considered doing the KOA Circus Circus. The 9.6 kW/hour of a NEMA 14-50 would be preferable to the 6 kW/hr of the J1772. Of course, the KOA will charge you $20 but perhaps some of that would be made up by the shorter cab ride.
Great move.Good point. I normally don't fill out surveys but I made a point of requesting more EV chargers in the Mandalay survey, when I got their "how was your stay email".
Great move.
At every hotel desk and every store I ask where the chargers are. Asking for management or concierge when I can. That combined with the Volt girl asking the same question the next day, etc., etc, is how we get it done.
You could ask to borrow a Roadster to MS adapter for a trip. This is why we have a club, to help our friends.
It may have already been mentioned, but I "discovered" two Tesla Roadster charging stations at the Venetian while I was looking for the Charge Point stations. They are located on level P1 under the Venetian, where the valet attendants park their cars and the taxi's line up before getting to the front area outside the lobby. All underground, covered parking.
The parking guards sent me down there first, when I asked about the charge-point stations. Since I don't have a Roadster, I didn't have an adapter. I hear they are very hard to get. But hopefully they will get them on the store soon, as they have added the other adapters and plugs over time.
Just curious, are the j1772 plugs all on the 6th floor of the self parking garage at the Venetian? Easy to find them? We are heading to Vegas this weekend and will charge up at one point to get back home.
And I have already been hounding TI to put J1772 plugs in their garage or at least offer 110volt outlets for use over the weekend. No luck so far.
I just made reservations at the Aria for June. I called and asked if they had any charging units available either j1772 or telsa hpwc (wishfull thinking). They transferred me to the valet and they said they have 4 14-50 nema outlets in the north valet (enter harmony street). They made it clear that we have to BYO mobile connector. Will find out when i head there in June, but has anyone else discovered this or charged there? I believe this is where Motor Trend stopped when they did there test.
My wife and I are heading to Vegas tomorrow- we'll be there from Thursday evening until Sunday morning. If anyone else will be there over that time period and wants to coordinate charging at the Venetian or exchange intel on when the spots are vacant, PM me and try and we can figure out the best way to share information.
Wow. If that turns out to be true, 4 NEMA 14-50s, that will be like finding gold. Those are certainly not listed on Plugshare or Recargo (or I would have looked for them). I saw the J1772 that is in the valet in the CityCenter underground parking lot, which should be accessible from Aria.
