I suspect the real change would be that the "brick" portion of the UMC would end up eventually integrated in to the car, and the cable would become just a simple cord with different plugs on each end. Of course then anyone who could get their hands on an end can make their own cord....
That violates article 625 far more than making the EVSE "fastened in place" for a lot of reasons - ground-fault protection, safety interlock, etc.
Then it would break J1772 functionality as well, and the car wouldn't know what current to draw.
- - - Updated - - -
How's that different than this?
GFCI is required for garage receptacles at 120V/20A or less, but is not required for 240V receptacles.
GFCI breakers at 50A run about $100, compared to the $7 or so for a GFCI 120V receptacle.
- - - Updated - - -
Well, collectively, the NEC doesn't know what it is talking about regarding portable EVSEs. Until the nirvana day comes when we have ubiquitous wall mounted EVSEs in all apartments, houses, workplaces, etc., we will need portable EVSE equipment. It is ridiculous to think that when people have a car that needs a charge, and there are perfectly safe 240V and 120V plugs everywhere, that portable EVSEs aren't allowed? As one of the commentators said, people are going to bypass stupid rules like this.
The reason I post the affiliations of the code-making panel participants is that policy-making bodies always have a lot of self-interest. The manufacturers' associations want to make money selling new gear (the reason for AFCI breaker requirements in NEC 2014), the contractors' associations want to install the gear, the unions want to force installation to be technical so you demand unions install it for "safety", etc.
BTW, Flasher (and others) what do you think of Europe's EVSEs that do not have an output cable. They require EV owners to carry their own Type 2 to Type 2 cable. I see several advantages to this European approach as opposed to the American one where all EVSEs have a 20' or so cable attached to a J1772 or Tesla handle.
In Europe, the public charges are much less susceptible to vandalization or accidental damage since they don't have an output cable. And private EVSEs are cheaper to install since they don't need a $200 cable. The only issue I see is how do you handle beefier current outputs. I suspect Europe doesn't have this problem since they can get high power from a 32A cable since they can have 3 phase power.
You point out some positives of the approach in Europe with "bring your own cable". However, it's important to note that the IEC 62196 standard requires a UMC-style "control box" for anything more than Mode 1 (direct connection to mains without control circuits), which is limited to 16A maximum. Some countries prohibit mode 1 charging as well, so you still have to carry an EVSE for portable operation.
Bottom line for me is that the IEC 62196 type 2 (Mennekes) connector is less user friendly than the Tesla02 connector (although better than the J1772), but I do like "bring your own cable" for the problems of vandalism. A charger I frequent in Normal, IL (not the supercharger) has a very touchy cord that easily stops the charging session even under some wind load. My own cable might help with that (but then you might find idiots shoving gum into the socket pins, so I don't think you're going to stop stupid).
