I want to purchase a Tesla vehicle (Model X) and use it to travel to our annual vacation destination in Orange Beach, Alabama. The Supercharger network will get us from Thunder Bay, ON to Orange Beach, AL but there are no destination chargers for our 5-week stay. The few destination chargers in the area are for patrons only and are not at condos. We stay at a rental condo with no EV charging facilities. Any suggestions?
Find out what socket has the most electricity at the condo. Sometimes you can find a 30 Amp 240 volt socket, get the right connector for a UMC that came with your car, and set the charging rate around 24 amps or less (maybe even 20 amps for safety). 20 amps at 200 volts is 4 kilowatts, so at 4 kilowatts per hour times 80% efficiency is ... 25.6 kilowatthours per 8 hours, or 31.25 hours to fully charge a 100kwh battery. If you're only using half the battery capacity each day on average per two day period and have it plugged in charging for sufficient amount of time, I think it's enough. Don't overcharge. Plan ahead for battery capacity per time period and trips away from charging. Have backup plans. And remember the less time you need to charge per day is the more time you get to spend at whatever day trip locations you're at. It's a juggling act, but with discipline it can work well. Most days will be easy, but every day requires distance planning to stay effective. When you're home with fire extinguisher the full 24 amps might be OK but remember not to use extension cords, and check the plug heating (bring any infrared gun you have to check it regularly and get a sense of comparison so each time you check it you know if it is being normal).
My main point is 240 volts is your friend as long as you are not a direct part of that circuit. The UMC that comes with every new Tesla car (and replacements sold by Tesla shop) is an effective cheap way to tap into that where available. Electric clothes dryer hookups are very often available. 240 volts is twice as much as 120 volts and can really make the difference without needing to increase wire size (USA standard wiring insulation is usually good to 600 volts, meaning 240 volts is already a cheap way to get more kilowatts without increasing amps), so you'll find it in many condos already.
Getting the right plug requires actually visiting the condo and ordering the correct part. Get one from Tesla especially made for the UMC if possible. That requires planning ahead. A photo of the dryer plug often suffices, so you can get the info before the trip, order the right part, and be prepared, but backup plans are necessary for the first few days in case of failure if you don't test it first.
