whitex
You're supposed to keep both hands on the wheel and maintain full situational awareness. Unless AP somehow turns the wheel with such strength that you cannot overpower, it is your fault - at least according to current fine print.I don't completely agree. I do think likely all the current crop of accidents are driver attentiveness issues but I also believe it possible that they are ways autopilot could fail that it would be impossible for even a fully attentive driver to correct for. This would be the fault of AP.
That said, I actually think that even inattentiveness can no be longer the considered driver's fault. As AP gets better and requires less and less user interventions, the more likely the driver will start paying less and less attention - that's just human nature. If AP was so good it only tried to kill you once every 6 months, there is little chance you'd be ready to take over. This has been confirmed by Waymo(Google) and other independent researchers. This is the reason why Waymo is going straight for Level 5. They don't believe Level 2/3 can be safely implemented. They believe the incremental approach is even less safe, but more importantly Level 5 is a while different problem than Level 2-4, so you can't get there incrementally (think for example trying to build a vehicle to go to the moon by extending a range of an EV car - yes you can say you get more and more miles of range, but no amount of range will get you to the moon as it's a whole different problem).
