Lane departure warning
Discussion in 'Model 3' started by ebmcs03, Jul 7, 2018.
  1. ebmcs03
    ebmcs03 Active Member
    So Cal
    I have it enabled but it doesn’t seem to work. Anyone else’s lane departure warning not work?
  2. Zaxxon
    Zaxxon Supporting Member
    Colorado
    Mine works. Wheel vibrates. What are you expecting/experiencing?
  3. ebmcs03
    So Cal
    No visual warnings?
    I don’t think I feel any wheel vibrations either. I will have to try again. Is there a speed limit? Like works above 28 mph?
  4. Zaxxon
    Colorado
    36-90 mph.
  5. ebmcs03
    So Cal
    Thanks. I should have RTFM. Oops. Although I don’t think i notice the steering wheel vibrations. Maybe I’ve been testing it at too slow speeds.
  6. Zaxxon
    Colorado
    Make sure it's actually enabled in your settings, too.
  7. Twiglett
    Twiglett Single pedal driver
    Austin
    Was going to say. What were you expecting if you hadn’t read anything about it first ;)
    I much prefer the wheel vibration to the stupid ringing alarms that go off in some cars. My wife’s Honda does that, really obnoxious chimes that go off when the car thinks you leaving your lane - horrible.
  8. ebmcs03
    So Cal
    Was experiencing nothing. It is turned on.
    I feel the vibration I think it was because of me trying under 36 mph
  9. miimura
    miimura Active Member
    Los Altos, CA
    The LDW steering wheel vibration is rather subtle. In fact, I thought it was a power steering servo feedback problem until I noticed the correlation with lane changes without signaling.
