Miimura, yes, the scenario would be with Powerwalls, thanks for noting that. So during an outage in sunny conditions, would the Powerwall inverters take over as the reference 60Hz until curtailment, and Tesla and other inverters would continue pumping energy as long as the frequency is within what their settings see as a "grid is up" situation.
When the power comes back on, is it the Backup Gateway that senses the inverters are back in phase before allowing reconnection to the grid, or do the solar inverters each determine that before allowing current flow from the panels? With different solar inverters, would it be likely they reenable at different times?
jjrandorin, I guess a concern of mine would be phase differences from different inverters, if that would be a concern at all, I haven't read too much about different inverters feeding into a Backup Gateway. I see that extra open breaker slot in my setup and the "what ifs" are running amok in my mind.
The Powerwall Gateway is responsible for the master frequency and the solar inverters all just follow along. When the Gateway detects that the grid is back, it does some checks to make sure the power is stable and then gradually slews the waveform so that the micro-grid is synchronized with the utility grid. Then it closes the switch and goes back into grid-tied mode. The back-to-grid transition is usually undetectable and solar generation continues uninterrupted because of this synchronization.Miimura, yes, the scenario would be with Powerwalls, thanks for noting that. So during an outage in sunny conditions, would the Powerwall inverters take over as the reference 60Hz until curtailment, and Tesla and other inverters would continue pumping energy as long as the frequency is within what their settings see as a "grid is up" situation.
In your case, 11kW of solar and only one Powerwall could definitely be an issue. The solar can overpower the charging ability of the Powerwall. You should think in advance about how to disable half of your solar. I'm not familiar with the details of the Enphase Combiner since I have an old Enphase system with each string of micros having their own 20A breaker in my easily accessible breaker panel. I also have the opposite problem to you - I have way more Powerwall than solar.I have multiple systems, 2 sets of enphase microinverters going into an enphase combiner, and a solar edge, from different sets of panels.
They take different amounts of time to come up from cold if they've been turned off, but I don't know yet how they'll behave with the gateway/powerwall shifting frequency to curtail them. I haven't had the default 65Hz setting changed yet, so my APC UPSs do trigger, but we'll have to see how the whole system behaves in a big outage.
My big loads (AC, EV charger) aren't backed up, so I have limited means for temporarily increasing consumption to help if I'm off grid and overproducing.
I had to convince the installer that this is what I wanted.In your case, 11kW of solar and only one Powerwall could definitely be an issue. The solar can overpower the charging ability of the Powerwall. You should think in advance about how to disable half of your solar. I'm not familiar with the details of the Enphase Combiner since I have an old Enphase system with each string of micros having their own 20A breaker in my easily accessible breaker panel. I also have the opposite problem to you - I have way more Powerwall than solar.
The problem with your situation is that you could drain the batteries during peak generation times, then when the sun is setting it starts to charge, but can't charge enough to leave you enough energy to make it through the night. Being able to turn off half of your solar during high generation hours will solve that problem. I don't expect your system to act like it has multiple inverters, the whole collection of micros should be acting as one even though they are arranged in multiple strings. The only improvement you can try to make is to get the installer to load a grid profile that allows proportional curtailment. However, they may tell you that those profiles are not compatible with California Grid Tie rules for things like ride-through.Here's the nuance with my system. I did a quick test flipping the main breaker when I had 80% SOC, and more solar generation than 1PW can sink.
It curtailed and went into battery only mode (zero solar).
That's what you'd expect to see with a 100% SOC on any system, but the issue with mine is that when it tries again, it'll see too much power available still and stay on battery until the solar output is low enough. That just means I'll be on battery for those hours even though it's daylight.
But, I do have the advantage that with the two different inverters, they'll curtail at different rates, so the system may find that middle ground where only one inverter is active, and that would be low enough output to restart charging.
Flipping the breaker for either inverter is sufficient, but the Solaredge does have a control toggle on it that would be less invasive, leaving it connected but not producing.Is manually stopping the Enphase system or the Solaredge possible from the manual shut off switches? All of the Solaredge inverters seem to have them, I'm not sure about the Enphase.
Would that bring it down enough to allow the Powerwalls to keep charging?
There are two parts to your internet, getting the local data to the Tesla cloud, and the cloud to you. Using a cellphone only helps if your Gateway can failover to cell as well...there are also things like extension cords...Flipping the breaker for either inverter is sufficient, but the Solaredge does have a control toggle on it that would be less invasive, leaving it connected but not producing.
The enphase doesn't have any similar physical control, and the app while great is monitoring only.
So I think yes, in the worse case scenario where I'm producing 9kW in mid June, using only 1kW and going into an outage, it'll switch to run on battery continually, but I can turn off 4kW easily and be under 5kW instantly, which the powerwall can use if it is at low SOC, but maybe just an hour later it'll be low enough for normal charging at 3.3kW.
I want to try this for real as a test, but currently my internet connection is partly powered from non-backed up circuits, so I can't monitor it seamlessly as I run the experiment. (Ah, could go Cell data only on the phone).
