Note: This feature currently requires accessing the site using the built-in Safari browser.
These are capable @250kw, SR+ is capped at around 102kw. So that’s 100kw is awesome for me.100kw is nothing.....
There’s still construction? JeezStandard Range Plus charging @ 100kw V3 Supercharger at the LINQ Hotel & Casino.
Pain in the Aśś to get to due to construction on the main road.
What do you usually max out at on a 150kw Charger?These are capable @250kw, SR+ is capped at around 102kw. So that’s 100kw is awesome for me.
Fred
An SR/SR+ will max at 100-ish. It’s been limited like that forever I believe. Only the trims above the SR+ get more power. Not sure it’s worth the extra money as 100kW can still get you some good range quicklyWhat do you usually max out at on a 150kw Charger?
I was at Rancho Cucamonga and those were 150kw chargers, I maxed out at 88kw.What do you usually max out at on a 150kw Charger?
Thanks! $50.00 for that License Wrap.I like your front license plate sticker
