Late 2016 / Early 2017 S Owners: How Are Your Daytime Running Lights Holding Up?
Discussion in 'Model S' started by houstonian, Jul 7, 2018.
  1. FlatSix911
    FlatSix911 Porsche 918 Hybrid
    Silicon Valley
    Unfortunately, the LED headlights in the current 2018 Model S are still poor compared to the Model 3 and pre-2016 Model S with HID lights.
  2. Naekuh
    Naekuh Member
    Los Angeles
    #122 Naekuh, May 28, 2019
    March 2018 build here and my DLR's are failing on passenger side.
    Im debating if i should get it fixed now before tesla decides to screw us over with not replacing it like the yellow screens, or if i should wait for tesla to release a fix to the yellow screens and get it exchanged at the same time..
    But here are pictures... sigh...
    Definitely these are Schrödinger's headlights as stated above.
    You do not realize something is dead until you actually go in front of your car with the door open.
    My front Bumper is wraped in Xpel.
    Anyone know if i need to get it removed to get the Headlight replaced?
    Im pretty sure they wraped the bumper around the edges, so it shouldn't require removal for the bumper to come off.
  3. Raechris
    Raechris Member
    Boston
    My 12/17 MS just had first DRL failure and had it replaced at the same mobile visit as MCU yellow screen replacement couple weeks ago. My car is wrapped in xpel and it did not even cross my mind - have since washed her and did not notice any issues.
  4. Mike Robinson
    Mike Robinson Member
    Atlanta GA
    I have SunTek PPF on my entire front, including headlights. My drivers side running light just turned yellow. I’m reluctant to get it replaced because I don’t want to lose the PPF protection
  5. _jal_
    _jal_ Member
    Chicago
    They don't remove the bumper. All the work is done from within the frunk. Actually, they remove the frunk and then replace the entire module. It's the size of a shoebox.
    And, the tech (fwiw) said that this is an ongoing issue. So, it isn't a bad batch of assemblies they got 3 years ago and are working their way out of. The 2019 MS are just as likely to have this issue as the late 2016. I looked really close at the bad module and couldn't see any obvious sign of water or other damage.
  6. ahkahn
    ahkahn Member
    Chicagoland
    I just had mine replaced back in January... both headlights. Just had the passenger side go out again, and they just replaced that one again. This is crazy!
  7. jelloslug
    jelloslug Active Member
    Greenville, SC
    They do remove the bumper. I just had my drivers side replaced a few weeks ago and watched them do it. I have Xpel on the front bumper also and it does not effect it.
  8. jelloslug
    Greenville, SC
    Yep, I have had the same problem. When I had my drivers side light replaced several months ago, it was bad almost immediately. Just as soon as I had that one replaced again, the passenger side one went out again.
  9. arcus
    arcus Active Member
    Denton, TX
    Check out this thread guys: Fluorescent Headlight "Eyebrow" Dying
    I had one of my headlights replaced last year, too. Both of them were showing the same symptoms, but SC fixed it by replacing just one of them (driver side, I believe).
  10. habanero69
    habanero69 I Dont Need Cialis. I Drive an EV.
    FLorida
    I had passenger side replaced on a 2016 refresh. I noticed a ballast hum coming from the light when off shortly after getting car. I was told on this forum it was a sign that it would eventually quit. About a year later it did. Service replaced. If they are LED I can't see why there would be a ballast involved. I can't imagine they are CFL, but LED require no ballast. Makes me wonder just what they are...o_O
  11. arcus
    arcus Active Member
    Denton, TX
    The are not: Fluorescent Headlight "Eyebrow" Dying
    I also thought they were LED, but the uneven "yellowing" made me think that it is not something you normally observe with LEDs.
  12. ⚡️ELECTROMAN⚡️
    ⚡️ELECTROMAN⚡️ In loving memory of Version 8
    Portland, Oregon
    LEDs use a driver instead of a ballast. Not sure how different a driver is from a ballast. That would be interesting if it was just the driver going bad. I wonder how replaceable it is. That might go with my heat theory as to what’s causing the problem. The drivers might not have sufficient cooling. I’ve noticed that a lot of complaints on here are from people from hot climates, but then again most of the cars are sold in California.
  13. jlv1
    jlv1 Twice as much fun
    Central MA
    I just noticed that the passenger side DRL on my S has this problem. It looks just like the picture in #122.
  14. Mike Robinson
    Atlanta GA
    I read another thread a few months ago wherein someone posted about replacing the LED lights himself, thereby avoiding replacement of the entire light assembly. I don't think Tesla offers to do that.
  15. _jal_
    _jal_ Member
    Chicago
    Geez, I’m sorry then. I kept an eye on them and never saw the bumper off, but I didn’t actually watch every minute of the whole process. It must have been off for a short while.
  16. ahkahn
    ahkahn Member
    Chicagoland
    They definitely don't take off the bumper under normal circumstances. This last time mine was replaced in my work parking lot in about 20 minutes. There was no way as quickly as the guy did it that he took off the bumper. He did, however, need access to the frunk.
  17. jelloslug
    Greenville, SC
    The bumper can be removed is just a few minutes if you have done it before. It does not have to be disconnected from the lower air dam though.
  18. Naekuh
    Naekuh Member
    Los Angeles
    well i submitted a service request.
    I am too scared to let it wait for the yellow boarder fix to get it all done at the same time.
    I am really worried they will push it out as "cosmetic" on that end as well, and charge for a new assembly.
  19. ZAKEEUS
    ZAKEEUS Member
    Denham Springs, Louisiana
    Replaced both less than a year ago, now they are burning out again.
  20. Mike Robinson
    Atlanta GA
    Was it done under warranty? If not, how much did it cost??
