SammichLover
Banned
"Squatting" has some benefit for RWD vehicles, as it loads more of the weight onto the drive wheels. Pointed straight ahead friction on your front wheels does you no good as they aren't putting any of your engine's power onto the ground, the front wheels just need a bare minimum of contact to keep you from veering off sideways.Of course I'm no automotive engineer but after seeing many drag cars squat down just before they launch
This is generally counter productive with an AWD vehicle as your traction generated per downward force (AKA 'gravity') on tires, the friction coefficient, is slightly lower as downward force increases. So optimum for a "launch" in an AWD tends to be towards completely even distribution of downward force between front and back wheels. Squatting still happens to an extent in an AWD, because the point at which you're grabbing the road is below your vertical center of mass so you naturally get some rotation of the front up and the back down, but you don't actually want it.
