Launch Mode Not Working
Discussion in 'Model S: Driving Dynamics' started by Soundchasr, Apr 16, 2017.
  1. Soundchasr
    Soundchasr Member
    Very close
    I've read the manual, watched videos and even read several threads to make sure I'm doing everything correctly but launch mode won't work for me. I have a P90D and every time I press the brake and then the gas I get a message that both pedals are pressed (not that launch mode is enabled as it should be). Anyone else have this issue or know what I could be doing wrong?
    Thanks!
  2. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    Do you have a P90D or a P90DL? (Is Launch Mode exclusive to the L variants?)
  3. Soundchasr
    Soundchasr Member
    Very close
    Just P90D. It is not supposed to be exclusive to L.
  4. Tech_Guy
    Tech_Guy ALWAYS IN LUDICROUS MODE! P90D>P100D Upgrade
    Los Angeles
    Do you have max battery power enabled. It should either show a time till its ready or say Ready! Under the max battery power text. Launch mode will only work with max battery power enabled.
    • Helpful x 2
  5. Ames
    Ames Member
    Abu Dhabi, UAE
    When you press the brake, make sure you feel it hit the bottom; if you don't Launch Mode will not engage.
  6. NovemberXray
    NovemberXray Member
    Portland, OR
    Ambient temperature also has to be above 37F.
  7. Soundchasr
    Soundchasr Member
    Very close
    Thanks. I didn't realize that it wasn't automatically in max power when in Insane Mode (I thought the text underneath was just an information link). I clicked it and now it ways 45 minutes until it's ready! Good thing I'm in no hurry to go fast.....
  8. Soundchasr
    Soundchasr Member
    Very close
    Do I have to do this every time I want to launch?
  9. jerjozwik
    jerjozwik Active Member
    san gabriel valley
    yes. thats why few people actually use it and why p90dL onwers are pissed this is the only way to eke out max power.
  10. Soundchasr
    Soundchasr Member
    Very close
    Yes, I'd much rather just hit the gas and go.
  11. sandpiper
    sandpiper Active Member
    Ontario, Canada
    You don't need to wait the 45 minutes. Launch mode is available, even if the battery hasn't heated fully.
  12. Navsarin
    Navsarin S100D Red Rocket
    Canada
    I have a P100D and same issue. Max battery was enabled, ludicrous+ Easter egg enabled, everything said ‘ready’ and all I got was ‘both pedals are depressed’. Brake was all the way to the floor and then pushed the accerator pedal to the floor and released. Launch mode would simply not engage :( max kw showed 527 and I was told a full launch mode would extract around 570kw.
    Has any update now allowed for full amperage without having to engage the launch with the pedals? I heard something about Tesla re enabling dull power and not having to activate launch mode specifically.
  13. Chasedrgc1223
    Chasedrgc1223 Nearly Insane
    NJ
    What was the outside temperature? I believe launch mode will not enable below 35 degrees or something like that
  14. Navsarin
    Canada
    #14 Navsarin, Nov 13, 2017
    It was -3celcius that day. 26.5F.
    Any reason why given the battery is heated up to 52degrees anyway?
    I’ll try again with warmer weather. Once I’ve tried it, I imagine I’ll seldom care to repeat it again and wear out the drivetrain parts lol.
    2.7 to 2.4...not sure if the body can even distinguish the difference :)
  15. Chasedrgc1223
    NJ
    I have no idea why they limit it, but here's the information. 37 degrees Fahrenheit is the minimum
