For people driving very high miles, I'm not sure EVs will work. Even with S, we should consider the battery. Typically 1,000 full charges before the capacity slips below 80% - and that will come in just 3 years, if charged from near empty every day.By complete coincidence, I talked to another friend today - a real estate agent who drives 40000+ miles per year and spends upwards of $7500 per year on gas.
He looked at the Volt and decided it was completely useless for him, because on a typical driving day ( 150+ miles ) he would use up the battery immediately and then be burning gas ( and not terribly efficiently in the Volt either ).
Neither the Volt or the Leaf is useful to him - I told him the details about the Model S and he is very excited about it.
That looks somewhat arbitrary - with no real intensity levels or frequencies mentioned. Is red on Leaf at the same level as red on Volt in those graphs ?Good article. Interesting info about the noise levels and frequencies in the Leaf.
You are still way ahead.....
I was talking more about 160 Mile S.If you charge the 300 mile Model S from near empty every day - lets call that 240 miles driven.
It all depends on what ICE you are comparing to but I guess you completely left out intitial extra cost of 160 mile S (and the electricity cost).Ok, but the math is similar for the 160 mile range Model S.
If you drive 120 miles per day, 365 days per year thats 43800 miles. Thats 1990 gallons per year and $7963 per year or $23890 over 3 years ( $25682 if premium gas )
*If* you need a new battery in 3 years - it will probably cost you $10000 - $12000, so you are winning.
I'd say that's slightly misleading. I've driven many cars with over 100K miles and none of them needed a motor rebuild. Other items, yes, but I'd say most motors are good for at least 150K these days with reasonable care.After 100,000 miles the ICE engine rebuild will cost when an AC motor is good for ten times that.
At least, and significantly more for a diesel.I'd say that's slightly misleading. I've driven many cars with over 100K miles and none of them needed a motor rebuild. Other items, yes, but I'd say most motors are good for at least 150K these days with reasonable care.
Yes - in the thread I linked - there are people have driven ICE for 600K miles - and apparently Prius without any problems for over 200K miles.I'd say that's slightly misleading. I've driven many cars with over 100K miles and none of them needed a motor rebuild. Other items, yes, but I'd say most motors are good for at least 150K these days with reasonable care.
Generally it means tear the motor down to the block, machine it as needed, and rebuild it. More likely would be a motor swap these days.So how do we define "rebuild"?
How about we just end all subsidies - upstream and for road use tax issues - for oil, and let the consumer decide what fits their needs? No, the Volt isn't an EV, it's got stupid extra maintenance, but as long as gas is so waaaay overly cheap, it looks better to the average joe than it should.
