AndrewBissell
You are the one who brought up the 80% "restriction" and the 15% margin of error, resulting in a range of 48 miles range for the Leaf. So people gave an example where Leaf owners drive 70 miles regularly "real world".
My 23000 miles and 2 years of EV driving has been in a Tesla Roadster. I am projecting my experience from the Roadster into the LEAF. IN the Tesla I use Standard mode as much as possible and avoid the upper 15% and lower 10% of the battery as far as possible. This is in line with Tesla guidance. So far this seems to have kept my battery in good state of health.
Given that the LEAF has 80% and 100% charge modes (similar to Standard and Range on the Tesla Roadster) I know I would be conservative and normally charge to 80%. Obviously on days I know in advance that I need more I'd charge to 100%. But every day use for me would likely stop at 80%. Other people may be happy to charge to 100% daily - and they may be fine. If I had a LEAF maybe I would get that confiden too. But prior to purchase for planning purposes I would assume 80% SOC at the start of every day. I think other people might look at it the same way. I know from this thread that plenty wouldn't!
As for the 15% at the bottom end - its a guess. But I know from the Roadster that I don't enjoy driving with "-- Range Uncertain". In the Tesla that happens below ~10-11% SOC. When that happens in the Tesla you've got 20+ miles left. In the LEAF that must surely be less than 10. That's anxious territory for me for two reasons:
- Lesser issue: will I make it to destination/next charger? Less of an issue because like most other commenters here I plan ahead and know how to eke out range by slowing down
- Bigger issue: am I damaging my battery pack? I err that one on the cautious side
But I'll happily change my estimate for the LEAF to assume just 10% at the bottom: it's got an EPA range of 73, with 20% at the top *I* wouldn't make available every day and 10% at the bottom *I'd* be reluctant to use. That gives an effective useable every day * for me * of 51 miles.
I agree completely, as that is the point I started with.If you look only at the EPA numbers the Volt stepped from slightly under half of Leaf range, to slightly over half of Leaf range.
I suspect the numbers for the 2013 to improve slightly also because it's going to end up using the 5-cycle test this year (rather than 2-cycle * 70%).
That's a good point and I look forward to that and it might change my estimate of useable daily range on a LEAF up a bit. Until then if I were cross-shopping LEAF and Volt I'd assign them 51 and 38 EPA miles daily driving before range extension respectively.
As a confident BEV driver or listening to all of you say you can routinely do 70 I might then apply a multiplier, say 70/51 and get:
Leaf: 70
Volt: 52
That tallies anecdotally with LEAF and Volt owners who claim over-EPA numbers.
However I'd also look hard at their driving patterns: if they are achieving these numbers with Bay Area climate and flat roads, I might not accept the multiple. Living in an area with hills and cold winters I might apply a discount. YMMV.
But I still think the LEAF:Volt ratio will be about 4:3 on the every day AER.
Or when pre-planned driving results in a 100% LEAF charge it's about 7:4.
In saying all this I'm not praising or dissing either car. They both have very good uses. Both are way better than driving pure ICE. And neither yet meets my needs in full.
