Does anyone know what this leaking fluid could be on my model S? There is a puddle on the driveway from this, feels oily?
You will.. When it gets low enough.Seems to be clear? hard to tell as the sun had dried most of it up. Would I not get a warning light if the coolant was low?
Tried that, still looks clear, maybe a very slight bluish tinge.Take a white paper towel/Kleenex and wipe some off the bottom of the car to see what color it is.
I'm not sure what would be clear. Maybe oil in the A/C system? Washer fluid?
But if coolant or the A/C was low I would expect you to have some warning.
Absolutely. With that much fluid leaking you’ll see what the cause is. Battery coolant heater, 3-way valve, 4-way valve, cracked washer fluid container, etc.It’s the front, will I see anything from the frunk?
That would be the best possible outcome!Windscreen washer fluid?
I’m assuming the floor damage was done before I bought the car in October as I don’t recall hitting anything.That would be the best possible outcome!
Can’t be as the reservoir lies behind front LH wheel-arc liner, all dripping would happen under drivers door on left side of the vehicle.Windscreen washer fluid?
