Leaking Soft Top
Discussion in 'Roadster: Technical' started by dhrivnak, Mar 31, 2011.
  1. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    I found out there is a good leak on the passenger side with the soft top on in the rain. It is leaking at the front top of the window. In looking close it appears the drivers side window is about 1/4" higher than the passenger side. Is this a relatively easy adjustment? Being 400 miles from a service center makes it a challenge to get there. When it is raining hard it is a steady drip on any passenger which is embarassing.
    Thanks to any help one can offer.
  2. doug
    doug Administrator / Head Moderator
    Yeah, there is a window adjustment. Try this thread.
  3. dhrivnak
    NE Tennessee
    Thanks but no noticable difference
    Thank you for the link to the posting. I suspected that was what the adjustment screws were for. I turned them 1 1/2 turs both clockwise and counter clockwise with no measurable difference in window height. I was nervous to take it farther so I guess I will wait for the service man to call.
  4. doug
    I don't think those screws actually increment the height. They are more likely loosened and then the window is adjusted by hand. Just my guess. Certainly talk with a technician!
  5. Talkredius
    Talkredius Member
    Hueckelhoven, Germany
    maybe you checked this already but just to be sure :
    one time I had a leaking problem too, but I just moved the window down and then up again, and then it fits.
    For an unknown reason the window had stopped to early while moving up before.
    Never happened again so far.
  6. dhrivnak
    NE Tennessee
    I did find a gasket along the top of the windshield did not have some sealer like the drives side. I added soem sealer and it appears that may have fixed the leak. Thank you for the suggestions.
