Thanks. Do you know if you can add a 3rd powerwall just because you think you need it if you are not on a subsidy? I have been thinking about adding one. Not sure if I will do it right away. I assume a PW3 will be appearing in a couple of years using the battery chemistry they talked about on Battery Day.
Adding the 3rd battery was because of many factors:
1) I looked at my actual home usage (like as a human being; not some Greenbutton pushing dolt), and determined 3 Powerwalls was in my best interest. Problem was I couldn't afford 3x Powerwalls.
2) I needed the 3rd Powerwall to be able to start an air conditioner when the utility was offline. The LRA of my Lennox units was deemed too high to even have one AC on the backup side with only 2x Powerwalls.
So my first plans (without the large-scale SGIP) was 2x Powerwalls as partial home backup.
3) If you look at that spreadsheet/picture I posted to start this thread, you'll see in the 4th week of November that: "PG&E planning identifies they are not comfortable with partial home backup solution since it would require two 125A breakers in the 200A main panel." Basically, PG&E was stopping my PV+ESS project because they didn't like Sunrun's partial home backup design.
PG&E and Sunrun never really did grasp the concept of a partial home backup where CT's metered loads upstream of the Gateway. As a result, Sunrun's designers actually relied in input from
@Vines (he has been super helpful since I joined TMC asking questions). Unfortunately, Sunrun's designers drew this up really weird on their line diagram, and had some wonky OCPD placement on the MPU. Plus, Sunrun confusingly labeled the air conditioners as "facility loads" which PG&E thought was like another house or ADU. Anyway PG&E hated this design and straight up rejected my second attempt to get a disconnect date without a new design being produced.
I leveraged adding the 3rd Powerwall to do the whole home backup. This got PG&E off my back after we resolved the 120 percent rule BS, and I was finally able to proceed on budget.
Bottom line, PG&E wanted me to abandon my PV+ESS as partial home backup. So, the
only way to proceed with PV+ESS was to apply for the large scale SGIP and get that 3rd battery. And now they're telling me my home is "sized wrong" SCREW THESE #@%$%*@ERS
