Leather Wear Warrantee?
Discussion in 'Model S' started by Brightonuk, Nov 29, 2014.
Tags:
  1. Brightonuk
    Brightonuk Member
    Plantation
    Is this a warrantee issue?
  2. eddie11228
    eddie11228 Member
    United States
    i would think so!
  3. trils0n
    trils0n 2013 P85
    SF Bay Area
    Before the Model S was being delivered, all the test drive vehicles had that same wear pattern. Tesla said it was from 100's of people getting in and out of the cars every day. Made me conscious to not rub up against that part when I get into the car. Not sure if that is considered normal wear and tear (seems excessive to me). You should ask Tesla if it can be replaced under warranty as it seems like excessive wear.
  4. swegman
    swegman Active Member
    I had the issue, thou it was much less noticeable as I was aware of the problem and was careful getting in and out of the car. Tesla said it is not a warranty item, as they consider it normal wear and tear. Having said that, they replaced it for me as "good will", but said it was a one time replacement. They replaced it because I started complaining about the problem within two months of getting the car, and it was documented with Tesla service. I note that on current production cars, that section is now plastic instead of leather.
  5. MoeMistry
    MoeMistry Local Vendor - SoCal
    Southern California
    I would consider that wear and tear since it's caused by making continuous contact. Try and take it too your local SC and see how Jolly they feel this time of year...they may take care of it.
    If they do, consider yourself on Santa's good list and keep an eye on it moving forward.
