Plugged in 5 years and counting... However I unplug the car end if there is a thunderstorm approaching.For my 3's next gen charging cable, is it ok to leave it plugged into the wall all the time, or should it be unplugged when not in use?
Ditto.No reason to unplug unless you’re going on a trip.
The Mobile Connector unit is light. I wouldn't worry about that. It certainly didn't strain the 120V outlet I left it connected to at the airport for a week and a NEMA 14-50 is a beast compared to that.Is the Mobile Connector controller light enough that it does not put excessive strain on the NEMA 14-50 outlet or the adapter pigtail?
Also, what is the consensus on the NEMA 14-50 wall outlet install height from the ground. The manual states a minimum of 18 inches but that seems low. Does anyone have a recommended height suggestion that works well for them?
The UMC locks to the car as long as the car is locked. So, it can not be stolen.Just remember that most wall units do not lock until it’s also connected to the car so dependant on location it could get stolen.
The height isn't really that critical. 18" gives it enough space that only the cord will touch the ground. For an install in my garage I'd want it high enough that I could see the charging indicator from across the room for a quick visual check on whether the car is charging. My HPWC is mounted so that the charge indicator is visible just over the roof of the car.
I measured just over a watt at idle:Someone measured how much power the UMC uses. I think it was less than $1 a year.
My power meter says 3watts. Probably less than that being it's a $17 ebay power meter.Someone measured how much power the UMC uses. I think it was less than $1 a year.
Actually, I'd unplug the UMC, too, in that case.Plugged in 5 years and counting... However I unplug the car end if there is a thunderstorm approaching.
