I can't help but wonder if it would be worth it (for self driving) to have cameras at the very front of the car that look left and right. Unprotected turns would be easier and safer, and it could eliminate over five feet of creeping.
This has come up many times. I have advocated for the idea of cameras as part of the headlight modules, which could solve some of the problems of retrofitting an improved hardware suite into existing vehicles. (I think, however, that such a significant retrofit is unlikely to happen.)
And BTW it's not only for side-facing cameras for left and right turns, though that's a major benefit. Another benefit would be
forward-looking cameras at the corners or A-pillars that would have a better angle to see past vehicles and obstructions when initiating a turn across traffic. A very common scenario is turning left from a left-turn bay, when there are cars in the opposite direction turn bay blocking your view of the high-speed oncoming traffic you have to cross. Even more so than with the side-facing B-pillar cameras, the view angle of the present forward-facing cameras is worse than the human driver's view.
Though as I said above, I'm not optimistic that Tesla would add corner cameras for new or for retrofit purposes, I think that another solution could be multiple or omnidirectional cameras in the existing repeater camera location. Looking forward, these could see down the side of the car with a somewhat better angle than the driver inside. Looking sideways, the repeaters are already forward of the door hinge which is an improvement on the B-pillar location. Another variant of this possibility is to move the repeater camera up a bit, to where the present window mirrors are located. Even if the requirement for conventional mirrors eventually goes away, it's not a bad location for a camera cluster.
If I were planning it from scratch though, I would use the corners, probably all four corners, for important AV cameras. These have the best angle of view when creeping forward, (or backwards out of a parking spot). The corners are also better for parking cameras to maneuver the car confidently and avoid curbs, debris, wayward toddlers etc.
