Left my A/C on MAX for 5 hrs
Discussion in 'Model 3' started by xpitxbullx, Jun 23, 2018.
  1. xpitxbullx
    xpitxbullx Member
    Las Vegas
    Just to test out how much juice it used, I ran my A/C on max for 5 hrs while at work. It used 60 miles of my charge. Perhaps I’ll check it out with half power later.
    • Informative x 10
  2. timk225
    timk225 Active Member
    Pittsburgh
    Most of the power is used driving the compressor, and that won't change. Running the fans at half speed will use less power but not as much less as you think.
  3. xpitxbullx
    xpitxbullx Member
    Las Vegas
    Rate of discharge is 12 miles per hour. So guy on the Internet said his Tesla only used about 10 miles all day. That would be about 1 mike discharge and hour. That must have been a guess.
  4. gaswalla
    gaswalla P4201/85/airsusp/pano/19i
    San Diego
    Why 5 hours vs 1 (or 10)? Curious
  5. chronopc
    chronopc Active Member
    That works out to about 3.8% battery drain per hour.
  6. xpitxbullx
    xpitxbullx Member
    Las Vegas
    I meant to do 1 hour but since I was at work, I forgot to check until 5 hrs passed by. :)
    • Funny x 8
  7. okashira
    okashira Member
    This is completely false. The compressor in any car, even a gas car is a highly variable load. Many gas cars use variable displacement compressors. Their load will also change a different pressure drops at the same displacement setting.
    And electric car ac compressor is even more variable as speed can be controlled directly.
    I estimate the model 3 compressor can operate as low as 300W up to 7kW. That would be typical for an electric car this size.
    • Informative x 3
    • Disagree x 1
  8. xpitxbullx
    xpitxbullx Member
    Las Vegas
    I just ran it for an hour at 70 degrees, fan speed 5, and recirculate.
    It used 4 miles of my charge. That only 1/3 what it used when it was set to max.
    • Informative x 2
  9. ℬête Noire
    ℬête Noire Active Member
    TX
    It probably was a relatively cool day, enough for A/C but maybe only a few degrees above. How much direct sun, and what latitude you're at is going to make huge difference, too. Because of windows a sunny day in Brownsville, TX isn't the same as a sunny day in Minot, ND even if the ambient air temp is the same. Also, quality heat block window film on the windows helps a lot.
    A/C energy use is highly dependent on how much temperate differential you're trying to cool across. Humidity in the air makes a difference (and related, how many people you've got breathing and making heat of their own ;) ). The A/C compressor is the lion's share of the energy draw, the circulation fan running flat out constantly will draw negligible amount of energy. When you're setting it to maintain a given temp the control system will turn the A/C compressor on and off as needed, even if the fan is running the whole time.
  10. xpitxbullx
    xpitxbullx Member
    Las Vegas
    My test was done in covered parking. 90 degrees in the shade. 11% humidity. Las Vegas is nice and dry.
    • Informative x 2
  11. ℬête Noire
    TX
    What did you have your cabin temp set at?
    My comment was aimed more at the claims of "guy on the Internet". Did they give any sort of list of variables?
    P.S. I manual tweak my Bolt's
    climate and save a good deal of range by "not sweating" a little heat. ;) I'll not even bother with A/C at all until it's mid-80's, just run the fan at manual setting. Even at the mid-90's mid-day on a scattered cloud day and NW Houston-ish humidity with the a good windown film I have I only need to run the A/C maybe a 1/4 of the time, to take the edge off periodically, if it's just me in the vehicle. That gets me about an extra 8% range. So instead of 10-12% of energy usage going to climate control it's about 2-3%. The Bolt breaks out climate control energy spent separately. If it's cool enough that I just run the fan with no A/C compressor it's not enough to register as even 1% of total energy usage, even if I have the fan set to highest setting.
  12. chronopc
    I just ran the A/C in my garage at 70 degrees setting and it dropped 5 miles in an hour.
  13. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I left mine on evening set at 71, 80 to 90 outside. I had wine in the car and wanted to keep it cool. 4 hours and used 3 miles.
  14. xpitxbullx
    xpitxbullx Member
    Las Vegas
    70 degrees. Fan speed = 5
    If it was out in the 108 degrees sun, I’m sure it would have to work harder:
  15. xpitxbullx
    xpitxbullx Member
    Las Vegas
    He didn’t give any variables. He was generalizing his conditions and guessing.
  16. chronopc
    Wow it only drained 3 miles total in 3 hours?
  17. Lloyd
    San Luis Obispo, CA
    4 hours!
  18. T-Will
    T-Will Member
    Rocklin, CA
    Maybe a silly question, but how did you keep the AC on for 5 hours without the car going to sleep? I thought if no one’s in the car, it turns off in about 15 mins. Or did you just leave your key card by the cup holder?
  19. Xenius
    Xenius Active Member
    Havertown, PA
    I can't be positive this exists on the 3, but on the S/X there's a "keep climate on" setting so you can force it to remain on. It'll shut off if battery drops to 20%.
  20. GWord
    GWord Member
    Houston, TX
    All that consumption stuff is well and good, but come on man, tell us what the interior temp got down to! :D
