Left Rear Door will not open
Alexgd
11
2
Alexandria, VA
The left rear door will not open, although the handle moves and the window goes down when I move it. The door feels like it's stuck at the bottom; it moves slightly. Has anyone seen this before and have an easy solution, or do we need to make a service call?
AdamVIP
526
300
I had a bad module that stopped my door from working. Mine was a little different though. The rear driver door wouldn't do anything from either the inside or outside and then sometimes randomly would pop open. The window would act funny too. I have a video where pressing the window switch activates the door latch. Real weird stuff. When they finally fixed it I was told they swapped a drivers side control module. Its worked perfect ever since.
Alexgd
11
2
Alexandria, VA
Solved by Mobile Tesla guy, who said he had never seen this problem before. The inside door panel had somehow scooted back a fraction of an inch so it was caught by the gasket on the door frame. Mobile guy adjusted the door panel in just a few minutes, and all is again well.
Reactions: KenC
