I think most people take into consideration that the charger might be ICEd so need a longer cable to plug into the carAny benefits to getting a longer one?
This is not good advice. There are more subtleties between the 11kw and 22kw cables. If you get an 11kw cable it will only charge at 3.6kw on a 7kw single phase charger. You need the thicker conductors on at least one phase to get the 7kw single phase. As you cannot predict which phase is wired through in practice you need a full 22kw cable to be able to charge at 7kw single phase.I would opt to get the longest one (if you get one rated to only 11kW ie the maximum the 3/Y can take) it will be thinner conductors so easily coiled and less weight. Also optionally remove 11mm from the male end to use as an extension and stop the risk of the cable being locked into the BYO Cable EVSE/Charger.
I'm looking to get the 7.5m type 2 cable that Tesla stocks, it's rated for 16.5kw. Do you reckon I'll get somewhere between 3.6kw and 7kw on a single phase? and do you see single phase type 2 chargers often?This is not good advice. There are more subtleties between the 11kw and 22kw cables. If you get an 11kw cable it will only charge at 3.6kw on a 7kw single phase charger. You need the thicker conductors on at least one phase to get the 7kw single phase. As you cannot predict which phase is wired through in practice you need a full 22kw cable to be able to charge at 7kw single phase.
That's what I use at home. Single phase up to 32A. I definitely recommend a 22kw cable for flexibility. Yes it weighs a bit more but I have had mine for 5yrs and no problems moving it around and carrying it.and do you see single phase type 2 chargers often?
The Tesla cable will do 22kW (32A per phase), but Tesla no longer sell any cars that can charge at that rate, which is why they market it the way they do.I'm looking to get the 7.5m type 2 cable that Tesla stocks, it's rated for 16.5kw
There used to be a large number of them in Perth but they're getting pretty old now and most are dead or dying now, I believe.do you see single phase type 2 chargers often?
I think the answer to this going forward will still be yes, you will see 7kw single phase chargers.and do you see single phase type 2 chargers often?
A 20A cable would only be rated to 14kW 3 phase or 4.8kW single phase. I am not sure why you think it would not fail 'on some weird 22kW charger' and that no 22kW charger is weird and actually follows the standards. And in fact challenge my knowledge on how a 22kw charger would limit a 11kW cable on a car capable of 22kW to only 11kW or even 14kW. I am hoping the standard dictates some form of resistor or otherwise in the cable to passively communicate the cables maximum amperage else risk over heating the cable. Someone more knowledgeable with the standard I hope can respond.There are situations when you need to pull the cable diagonally over the entire car, because you cannot turn the car around for various reasons. In these situations you need a 7 m cable in my experience.
I have bought one that is rated for 20 A, so it does not fail on some weird 22 kW chargers, and that has the "Tesla button" to open the charging port and to stop charging. I just used it today in a one-way street where I could not turn the car around. The cable is quite a bit thinner and lighter than the long 32 A cables Tesla sometimes provides with new cars.
However, I'm in Germany, not in Australia. Perhaps there you always have enough space to turn the car around, so you only need a 4 m cable. In Germany, streets can be narrow, traffic can be dense, and rules can be very restrictive.
It does, but can you be sure that all these cheap thin cables from dodgy factories are putting the correct resistor in?I am hoping the standard dictates some form of resistor or otherwise in the cable to passively communicate the cables maximum amperage
I don't know the details, but over here in Germany there are some 22 kW chargers that refuse to charge at 11 kW if the cable is rated at 11 kW only. In my view this is a defect of these chargers. The hypothesis is that this way they are a bit simpler and cheaper to build.A 20A cable would only be rated to 14kW 3 phase or 4.8kW single phase. I am not sure why you think it would not fail 'on some weird 22kW charger'
Your power figures don't exactly match what we have in Australia, but I'm betting its the same problem we encounter as follows:In my view this is a defect of these chargers
The typical problem seen is the other way around: an 11kW three-phase cable attached to a 7kW single-phase charger can only deliver 3.5kW because the 11kW cable is 3.5kW (16A) per phase.Typical Type2 cables for sale are 22kw and 7kw. Despite most cars not supporting 22kw (most capping out at 7kw/11kw or thereabouts), it's recommended to still buy the 22kw cable. Why? Because the 22kw cable is three-phase, whereas the 7kw cable is single-phase. On a 22kw charger, both cables will hit their marketed power, but on an 11kw charger (which are very common here), the single-phase cable only delivers 3.5kw. This is because the 11kw charger is 3 phase, and the cable is only able to deliver power from one of the phases. The 22kw cable will deliver the full 11kw.
Hmm, not sure which is more typical but I guess both are possible and reinforce the recommendation to go 22kw.The typical problem seen is the other way around: an 11kW three-phase cable attached to a 7kW single-phase charger can only deliver 3.5kW because the 11kW cable is 3.5kW (16A) per phase.
