So
@yobigd20 , could you tell us what happened next? Hope your car started to charge after one hour or so... Battery heater is 6kW so 240V x 29 = approximately 7kW. You need like 40A or more to charge a very cold battery... You already know this I think though.
I was on the phone with Tesla for over an hour.
Basically at 10 miles range , the battery was in a 'cold soaked' state, and would only accept a charge rate at 1A until the battery state of charge was > 10%, at which point it would resume a normal rate of charge. There wasn't anything wrong with the charger itself, since when I turned the cabin heat on you could see on the display and on the chargepoint unit that it would jump up to 30A. But turning cabin heat off it falls back to 1A. The power was there. The car just wouldn't use it for normal charging or heating the battery pack.
So I waited 4 hours sitting there charging at 1A, at which point it only accumulated 4 miles now up to 14 miles range. Started at 6:30pm now at 10:30pm , still half the range of what I needed to get to the supercharger at the rate it would eat it. So I found a holiday inn 1.5 miles away that also had an L2 charger. So I headed over there, of course eating 5 miles range to get there. So its back to 9 miles, still cold soaked, and I had to start process all over again and I got a room for the night. It only charged about 1-1.5 miles/hour before it got to 10% around 25 miles and then it kicked up to charging 6-7mph. It basically took about 10-12 hours to get out of this cold soaked state to resume normal charging. Once I had enough charge I left and went to supercharger which charged normally.
I've taken the car down this low before many times but never encountered this state before. The Tesla guy said basically it would only pull this 1A until it got itself out of this state, but that most of that 1A was being used to try and warm the battery. It would not use any more power than that to warm the battery any faster. He was remotely monitoring the car and the battery temps and the temps just would not increase until after the SOC was over 10%, and once that happened then it would use 30A to charge the car.
I've had this car 5 years now, 163k miles, taken it down lower than 10 miles many times. although last month the car did shut down on the highway with 8 miles range left on display. (NO RESERVE PEOPLES....hate it when I see people say 'car has 10-20 miles reserve', just not true. battery range is estimation, and like what happened to me has happened to many the car will shut down even when it shows +range.)
Anyway, throughout 5yr/163k miles never once saw this 'cold soaked state' before where it refused to charge or warm the battery pack until it was over 10% state of charge. this must be new in some recent software update...prettty crappy. I'll have to make sure never to bring the car that low again, and never to leave it parked if its under 50 or so miles range on the display because i dont want to get stuck for 12 hours again.
