Yet another example of 30A public L2 charging being woefully inadequate for cold climates.
had nothing to do with the amount of power on the charger. the car itself would not PULL more than 1A until it was over 10% SoC.
Do you know, why the car didn’t want to warm the battery? I understand, that it didn’t want to charge coald soaked battery, but why the car didn’t want to warm the battery?
no idea, and the Tesla guy on the phone just kept saying this is normal for a cold soaked battery until its back over 10%
What about actually charging the car and running the heater concurrently?
we tried this while Tesla was remotely connected and monitoring the car. the theory was that the cabin heater blasted at max would indirectly help warm the battery pack so it could get out of being in cold soaked state. unfortunately, having the cabin heater on had 0 effect on the battery temp, and we had it blasting for a long while. Having it on did *not* drain the battery at all either. Basically the battery pack was still being charged using only the same ~1A to trickle charge the battery pack while the rest 29A was being used for the cabin heater but having the cabin heater did not warm up the battery pack. For about an hour he was able to see an increase of charge state from 5.2% to 5.4%, while the temperature of the pack remained exactly the same with no increase.
oh please, i'm an early adopter (VIN 05837) have had the car over 5 years and driven more than 163k miles on it. I've probably got more experience here with all the little quirks of this car than 99% of any other Tesla drivers, especially given the early build and all the fun stuff that none of you later models had to deal with. I have driven this car from 100% to 0-3% on countless occasions, in the freezing cold and in the summer heat. Never once have I had this happen. This 'cold-soaked' state is something new due to a software update, i'm just not sure which version they added this slower charging < 10%. It has to be fairly recent in the last year or so.
LESSON TO BE LEARNED:
Stop at Supercharger for a high level charge prior to parking overnight in freezing temperatures. This way, even with a cold soaked battery you can start to drive which will warm up battery and cause the rated miles remaining to increase as you drive.
NEVER park overnight in freezing temperatures at a very low charge level. You my be spending a good portion of a day or more just trying to warm up the battery so you can start charging to get to the Supercharger. Imagine that you only have a L-1 or 120v outlet to plug into. In that case you will have to pay for a tow truck to carry you to the Supercharger.
yea well that goes without saying. However an L1 or a 120V would have made no difference here, since it would still only charge at ~1A. and there was actually a 120V outlet at this location too, and we did try it. The result there was that instead of it pulling ~1A (it must have been between 1 and 2A because it would flicker back and forth but mostly stay on 1A), but on the 120V 15A outlet it would only pull ~2-3A, which from what the Tesla guy could see in the readings was charging the car almost exactly the same rate as it was when it was pulling 1A 240V from the L2 charger. So the outlet type/power available made no difference here.
Since i'm wayyyy past warranty, when the car shut down a few weeks ago it cost me $440 to tow it to the service center. Given that, I opted for the hotel room instead and keeping it plugged in for 10 more hours which only cost me $125. I'm cheap. well, that and the in-laws were visiting so there was no real good reason so race home any sooner haha
