The box that displays "parallel" can switch to "series," connecting the two loops together for heating. The valve that's shown below "chiller" is for cooling the battery.
True, but that series connection connects the battery and motor/inverter coolant loops. It still doesn't connect anything to the cabin heating/cooling system.
I assume these are from the other day and not right now.
The slow supercharging is likely due to the cold battery temperature. It can take a long time for it to heat up enough to allow full speed charging.
Maybe a silly question, but have you ensured range mode is off? I quickly scanned this thread and I didn't notice you mentioning it.
If it is off, this has to be a software bug. There's no reason not to be drawing the ~6 kw for the battery heater.
I can see turning off the battery heater if you're cranking the cabin heat and shore power can't keep up with both heater systems with SOC<10%, but this behavior is unacceptable.
Aside from a few minor features (in my "classic"), version 8 is a terrible disappointment. Not only do I now have to be conscious of my app placement, and hiding map icons when I need them most, I have to be more cautious about my end-of-day SOC traveling in cold weather; lest I be sitting at a SC for a day!
This would be great a great feature on both ends of the temperature scale. In the winter to let you warm the pack in preparation for supercharging, and in the summer to cool the pack to delay the onset of the ramp as much as possible.This isn't new in version 8. Tesla has never had a way to prepare the pack temperature for supercharging speeds.
and here is my car right now once again slowwwwwwwly charging at a supercharger tried 5 stalls cant get higher than 32A.
I wasn't really thinking about preparing to supercharge. Just if you plug in and the power's there, turn on the battery heater. From the OP's experience, if the battery's too low, it will not turn on the battery heater even if there's plenty of power; so no matter what you're stuck for a day while it trickles to 10%. Bogus.
