If you are expecting / hoping for an update to the software version on your vehicle but not receiving a notification, you can “force” a check by going to the Software menu via the car button bottom-left
Pressing the park button on the shift lever after you have pressed park once - unlocks the doors
You don’t have to use the X buttons top-left of windows to close them, just tap anywhere around the pop-up window to return to map view
If you disconnect the door card puddle lights the door handle electronic release stops working and glass will return to highest position until you reconnect the puddle light
The WiFi receiver is in the right-hand door mirror so be sure to park the correct way round to get better connectivity to target router and stop you swearing lots
If you start a wifi-based download for software/game/nav and have premium connectivity (not tested on partial-premium), you can disconnect WiFi and the download will complete via the car’s in-built LTE
Your brakes are in use a lot less than ICE cars so don’t forget to use them properly on a semi-regular basis, they will thank you for it and emergency stops will work better / be more predictable
Your tyres are crucial as with any vehicle but to maintain range/suspension performance be sure to check them regularly when cold and keep an eye on their rolling pressures by swiping left at bottom-right of screen.
Assuming you have reliable home charging, warm the battery up by triggering climate/heating from your phone 20-30 mins before you leave as the weather gets colder, will make your first 1-20 miles much more efficient. It will cost you a few KW on the leccy bill but will pay back through less range anxiety/recharging needed due to lost range.
