Lessons learned about USB audio
Aug 1, 2018
43
25
bakersfield
Hi guys, I want to share what I've learned about getting my music to read correctly on the media player through my USB flash drive. It's taken quite a bit of trial and error to get the media player to read everything as it should.
Disclaimer: this has worked out for me; and focuses on MP3 files (how my digital music is stored).
I'm using a Samsung 128GB low profile USB 3.0 flash drive in my Model 3, with about 69 GB worth of music on it. With this drive and this amount of music on it, the car can take anywhere from 10 seconds to 3 minutes reading or caching it (or whatever it's doing) before it lets me access it. It seemingly needs to do this every time I start the car, regardless if anything on the drive has been changed or if it was left in/removed. I think this is an area that Tesla can improve.
First thing, drives larger than 32GB are usually formatted in exFAT or maybe even NTFS, and drives 32GB and lower are formatted in FAT32. Modern operating systems and firmware don't usually have a problem with any of these formats. But our high-tech shiny Tesla vehicles, from what I've experienced, only recognize the ancient FAT32 format! (I find this laughable). I'm not an Apple or Linux user, I use Windows 10. And Windows 10 has ditched the ability to format flash drives and sdcards in FAT32. So what's a person to do? Google of course! There are several formatting programs that used to work in Windows 10, but it seems most of them don't anymore. Thankfully, I've found one that still works great, at least in my limited experience. It's called SmartDisk_FAT32_Tool from Verbatim. It's available here MEGA
Once you've properly formatted your drive, you can add your music files onto the drive. But things are still not yet so simple.
Normally, on my PC, phone, or my living room audio receiver, the music player software reads the ID3 tag to determine song order and album order. As such, the filenames of my digital songs weren't always so clean, but it was never a problem thanks to having organized IP3 tags. I use Mp3tag to organize my MP3 files. Tesla, for some reason, relies a lot on the actual filename to determine song order, and album order is ALPHABETICAL, which annoys me because I like seeing my artist discographies in order. The Tesla media controller is also a bit picky about how your numbers should be.
If your filenames start with 1., 2., --10., 11., etc, your songs will be a bit out of order. You need to have a 0 in front of a single digit (i.e. 01., 02.) unless the album has less than 10 songs in it. Also, you can have the numbers formatted like so
01
01_
01.
01-
and maybe other ways, and the order will be fine, as long as it is consistent throughout the folder. If your songs for some reason are labelled like this (say you downloaded a bonus track not available on your album and put it in the folder)
08_
09_
10_
11.
12_
you're likely going to have something out of order.
To solve the album ordering problem, you can either rename the folders like this:
01_"album 1"
02_"album 2" etc.
or label them with the release year
1998_"album 1"
2001_"album 2" etc.
Album artwork needs to be embedded into the file itself to be consistently read by the media player. This is the ideal way to do it anyway, and how I already had my files tagged. Mp3tag does this easily. My go to place for album artwork is https://albumartexchange.com/ You need to register, but it's free. For CD ripping software, these days I use Foobar.
So after painstakingly fixing the problems I had with the filenames of my music, I was all set, right? NO! Some of the albums or songs would have "Loading Error," even though they were MP3s and playing the USB drive on my PC didn't have any issues with these songs. So what was causing the problem? Using Mp3tag, I saw that these problematic MP3s, in addition to having ID3 tags, also had something called an APEv2 tag. These tags have never posed a problem in any other devices I've used for playback, but our shiny high-tech Teslas can't handle them. Using Mp3tag options, I was able to easily remove the APE tags from these songs and fix that problem.
So there you have it. Learn from my experience to format your music correctly. I think the media player is ok, but there are definitely areas for improvement.
I want to see:
No need to recache everything from the drive if the drive was never removed from the car, so that it's instantly available. This should allow the car the ability to remember what song you were listening to and to resume
Resume song from USB after you turn on the car needs to be here
Scrolling titles while playing for long titles that don't fit
GAPLESS playback
and I would also like the option to see a larger version of the album artwork. My artwork is usually encoded at a minimum of 600x600, so it would be great to see that in much better detail in our cars
43
25
bakersfield
I know about FLAC, I considered it. I rip MP3s in LAME v0 (high bitrate VBR), and to my ears I've not heard a difference between the MP3s and the original CDs on my audio setup. For a collection as large as mine, I'm happy using the MP3s.
soulstar
22
21
Good read, thanks for the guide.
I've ditched the USB for now. I prefer USB over bluetooth from my phone but I have a weird tendency to want to skip songs around depending on mood. Sometimes I shuffle the whole library and decide from there as I drive. I don't mind doing all the file renamings and tag removals but until they put some more flexibility on the USB media, I think I'll stay off.
Reactions: Deal and fiatlux
sduck
Mr. Duck
Nov 6, 2017
1,388
1,394
Nashville TN
I also gave up on the USB audio system, at least for the moment. I also sent a very detailed list of bugs and feature requests to tesla, and was assured that it is being worked on, and that a big update is coming. I hope that's actually true.
Knightshade
11,150
14,458
NC
I have high hopes v9 of the software coming out next month will include a vast improvement in USB audio.
Because it's by far the least-crap audio quality option on the Model 3 but the interface is awful.
Aug 1, 2018
43
25
bakersfield
So recently, while my 3 was getting it's windshield replaced, I had a 2014 Model S as a loaner. Using my same USB thumb drive, the Model S flawlessly resumed USB playback every time I got back into the car. It even remembered my last USB position when I switched audio sources. It took longer to cache when I inserted the thumb drive; a good 10 minutes to read about 69 GB of music. But then it remembered and never needed to cache it afterward. The loaner appeared to have recent software.
So hopefully this bodes well for a fix for our 3s in the future.
Reactions: KnoxEVfan
SVDNN
42
21
SF Bay Area
Saw your discussion on similar thread but wanted to help you clarify by comparison...
I have had no problems uploading 125Gb of FLAC files on 128Gb Sandisk USB in about 1-2 min in M3 on initial insert. I do not experience the USB having to reload files on restart.
Would agree that the M3 does not startup at same USB song nor even have USB media input selected (defaults to bluetooth). Whereas, in my model S, it will resume exact USB track position and start music automatically on restart. But also has done this for at least couple years (not a part of recent software update). So, I would be optimistic that they will eventually send out software fix for M3.
As to the issues you have for M3 reading your USB efficiently, sorry to hear. Just here to say... I do not have the same issues with twice the amount of data on USB. My USB files were created directly as FLAC files from CDs and no tweaking of file tags.
Hope that helps to narrow down the issues toward a fix...
Aug 1, 2018
43
25
bakersfield
Interesting. My music is in MP3. I'd be happier if at least my car didn't have to reload the thumb drive every time I got in the car. I wonder if getting a SanDisk thumb drive would be better in this regard. Still, makes me wonder why it works so great in the S and not the 3.
judyjetson
106
79
Charlotte, NC
I've got a bunch of m4a files, which i believe is an iTunes format. This format doesn't seem to play on a flash drive in my M3. What is the best program to convert these to flac?
animorph
2,130
1,521
Scottsdale, AZ
I converted them in iTunes itself. Convert to Apple Lossless Format, or something very close to that.
ETA: Flac is most useful for ripping CD's. If you are just converting normal iTunes purchases, converting to one of the high bit rate MP3 versions in iTunes should be fine and save you some storage space.
Wattzup
9
7
Florida
Don't mean to highjack your thread but maybe you can help me. I have a 128gb with 32gb FAT dashcam partition with the rest partitioned for music with like 7000 songs on my USB and it takes over an hour to cache which I am at my destination by. I tried remove the APE tags with mp3tag but that didn't seem to help. Any thoughts on why it takes so long to cache?
Aug 1, 2018
43
25
bakersfield
Not sure, except maybe if you are using a USB 2.0 device, switch to a 3.0 device (higher speed). On update to v9, it still takes some initial loading for me, but it's usually available in less than 10 seconds. An hour, I really don't know why.
kid_iculous
New Member
Oct 17, 2018
2
0
Wisconsin
I'm working through similar issues. Yesterday morning, it took my entire 20 minute commute to get 73% through the caching. Getting back in the car in the evening, it got to 73% quickly but stalled.
Since I had recently been doing a lot of file tagging, I noticed lag when saving tag changes to files with huge album art. I used a program named dbPowerAmp (21-day free trial) to reduce the size of all my album art to 200x200 and 20kb max and put about 70% of what I had yesterday back on the flash drive. This morning, it took about 3 minutes to do the initial index. So my guess is that it's scanning through the huge album art when loading the track names, and that's causing major slowdown.
You can add a custom column in mp3tag to see how big the album art is. I don't remember the exact steps but it wasn't hard.
(This is still only about half the music I ultimately want on the drive, but I'm working through test cases one by one, slowly.)
kid_iculous
New Member
Oct 17, 2018
2
0
Wisconsin
(Editing disabled immediately after posting? That's annoying.)
I realized I also wanted to add - with the inconsistently sized album art, the progress counter was noticeably inconsistent, stalling out on various numbers. With the shrunk album art, it was rather consistently progressing. So that might tell you if that's part of your issue.
Wattzup
9
7
Florida
I
I tried wiping all of the album art with no luck. I uploaded a few hundred songs (with the ape tags and album art) and it loaded pretty quick but not I added like 3 thousand and hope it'll work fine.
Aug 1, 2018
43
25
bakersfield
I'm not sure album art size affects loading. All of my album art is typically 600 x 600 and I have about 10,000 some on my USB drive. Usually loads under 20 seconds. I'm finding that sometimes, if I'm lucky, the car resumes my last played USB song!
Csusch
11
11
Chestnut Ridge, NY
01
01_
01.
01-
08_
09_
10_
11.
12_
01_"album 1"
02_"album 2" etc.
1998_"album 1"
2001_"album 2" etc.
I want to see:
GAPLESS playback
Ever since getting my Tesla Model 3 more than a month ago, my USB holding approx. 100gb of music requires a reload every time I restart the car. Are others experiencing this as well? I see at from this quoted post that you experienced this on your model 3, did you figure out a way to resolve this?
